Go to Post A Mentor is.. A person you can talk to anything about and trust them to not throw it back in your face in any way shape or form and who will help you as much as they can to deal with the problems and situations in life... - Elgin Clock [more]
Unread 29-06-2015, 22:02
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
Rookie Year: 2013
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
Summer Swerve Project
This is the current project that I am working on.
The "cream" colored parts above the module are 3d printed, similar to those on 1991's 2015 swerve modules, except much smaller.
Unread 29-06-2015, 22:16
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Summer Swerve Project
Looks very light and strong. A few questions:
-Any reason why you chose to go with a live axle instead of a dead axle (or are you just using a 7/8" bolt)?
-How are you constraining the pulley on the CIM shaft radially?
-Are you broaching the bottom miter gear for a 1/2" hex shaft?
-What are your free speeds and weight?
<Now accepting CAD requests and commissions>
Unread 29-06-2015, 22:27
TAlholm's Avatar
Mainely CAD
AKA: Tim Alholm
Rookie Year: 2013
I will be changing it to a 3/8" dead axle, keeping it as it is for now to allow an easier time when putting in different setups (i.e. sprockets, pulleys, gears)
The bottom miter gear will be a keyed 1/2" bore, and the rest of the shaft will be 1/2" hex.
Free speed is currently 15.89 ft/s with a 5.83:1 reduction. Will be reduced more if I change the top HTD pulleys to GT2. The weight will be posted once I add the rest of the parts.
Unread 29-06-2015, 23:11
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Where is that miter gear coming from? I haven't found a good source for keyed miters yet. Unless you already own a key broach and not a hex (which I would recommend buying; they're quite useful, if expensive).
16fps is a good number.
Unread 29-06-2015, 23:51
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
This is a 1/2 keyed miter gear that has the same DP and teeth count as the vexpro miter gears. It's expensive though, at $82 a set.
Does the OP have a cheaper source?
FWIW, I do agree that a hex broach comes in handy.
Unread 30-06-2015, 13:08
TAlholm's Avatar
Mainely CAD
AKA: Tim Alholm
Rookie Year: 2013
This is the miter gear I have chosen.
I will be looking into using a 1/2" Hex broach for it, thank you for the recommendation.
Also, the weight is roughly 6.75 pounds.
