Go to Post Remember, the song is FIRST and the competition. We are the group. We dance to FIRST, we move because of it. - Joe Matt [more]
Unread 07-01-2015, 12:05 AM
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
Rookie Year: 2012
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
DoubleSolenoid question
Alright, so i'm working on just re-writing our 2015 robot's code so that it's a lot cleaner and whatnot, so future students can see a good example of a good project.
my question - one that i ran into during build season but never tested - is this: if i instantiate a double solenoid object, then put it in the Value.kForward position manually in teleop, then turn the bot off and re-upload the code, will the code be able to recognize that it is in the Value.kForward position during disabled?
the order of code being run:
first time:
Code:
public void RobotInit(){
    piston = new DoubleSolenoid( ... , ...);
// then:
public void TeleopInit(){
   piston.setValue(Value.kForward);
// then i power off the bot while piston is in forward position, and this happens after i turn it on again and reupload code:
// then in disabledPeriodic
public void DisabledPeriodic(){
    if(piston.get() == Value.kForward)
        System.out.println("it's in the forward position");
    else
        System.out.println("it isn't or we don't know");
what would print in the example?
Alumni & part-time programming mentor of 2791.
My views do not reflect the views of my team.
2012 - BAE Granite State Regional Finalists & Imagery Award, Connecticut Semifinalists & Creativity Award
2013 - BAE Granite State Regional Quarterfinalists & Quality Award, WPI Regional Finalists & Excellence in Engineering Award
2014 - New York Tech Valley Quarterfinalists, Finger Lakes Semifinalists & Quality Award
2015 - New York Tech Valley Quarterfinalists & Quality Award, Finger Lakes Quarterfinalists & Industrial Design Award
2016 - New York Tech Valley Semifinalists & Quality Award, Finger Lakes Semifinalists
Unread 07-01-2015, 03:09 AM
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: DoubleSolenoid question
No, it would not remember the setting after a reboot. Any new solenoid object always initializes to kOff. So it would print "it isn't or we don't know".
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 07-01-2015, 08:22 AM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
While the software wouldn't know, the hardware would probably still be in the same state. Double solenoids only change state when strobed, or when the little manual button is pressed - AND the supply port is pressurized. (Or they're taken apart,)
Unread 07-01-2015, 11:36 AM
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Rookie Year: 2012
Alright, thanks a bunch.
Yea, I was just wondering if the software would know. We always just had it reset itself to retracted in autonomous but it was a minor pain in the pits when nothing worked until we hit the extend button on the controller again.
Unread 07-01-2015, 11:50 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
If you add an automatic reset in the initialize routines for teleop and test modes, this should resolve the issue. Because the valves are piloted, you may want to wait until the pressure switch is engaged so you know that the switch will occur.
Unread 07-01-2015, 12:48 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The FRC legal valve is a bistable device. The code is open loop (no feed back) Without a sensor to confirm the valve position, the code doesn't know what position the valve is in. When using these valves, I always have the programer keep the solenoid energized if the valve position is important. (Yes they will generally stay in the last energized position.) Obliviously there is no way to keep the solenoid energized with the robot disabled.
If you don't know what you should hook up then you should read a data sheet
Unread 07-01-2015, 01:02 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Originally Posted by FrankJ View Post
The FRC legal valve is a bistable device. The code is open loop (no feed back) Without a sensor to confirm the valve position, the code doesn't know what position the valve is in. When using these valves, I always have the programer keep the solenoid energized if the valve position is important. (Yes they will generally stay in the last energized position. Obliviously there is no way to keep the solenoid energized with the robot disabled.
The KoP valves are bistable devices. The only limitations I am aware of for FRC legality is:
Originally Posted by R66
The only pneumatic system items permitted on 2015 FRC ROBOTS include the items listed below.
C. Solenoid valves with a maximum 1/8 in. NPT port diameter,
Automatic return valves which meet this requirement are also available at AndyMark and elsewhere. Especially if you're going to have your pneumatics in one position most of the time, this may be a good solution to your problem.
Unread 07-01-2015, 01:48 PM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The KoP valves are bistable devices. The only limitations I am aware of for FRC legality is:..
We use the Automation Direct stuff. Works great. AD is a both a national & Georgia state First sponsor. Great company, good prices, fast shipping. (free 2 day for over $49)
Back to the point, for which I should have been more clear, was specifically for dual solenoid valves. You can buy a spring centered dual solenoid valves (mono stable). If you use one in FRC, the center section would have to be able to vent the discharge ports when system pressure is released. The spring return single solenoid valves also has to be able to vent the discharge ports when pressure is released. Not all do. All of this is not really relevant to what is essentially a control question. I generally prefer the single solenoid valves because they take one less output to do mostly the same thing.
