Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 02-07-2015, 09:54
klink135's Avatar
klink135 klink135 is offline
The one dat pushes da buttons
AKA: Max Jorgensen
FRC #5050 (Cow Town Robotics)
Rookie Year: 2015
klink135 is an unknown quantity at this point
Exclamation Labview won't open
I have been trying to get labview on my laptop to start practicing more with the system, but I can't get the program to open. When I try to open or run labview.exe nothing happens. Please help!!
Unread 02-07-2015, 10:04
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Labview won't open
How did you install LabVIEW? From where did you get the installation file?
Unread 02-07-2015, 10:07
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
I used the instructions from First and National Instruments. The file came directly from national instruments.
Unread 02-07-2015, 11:57
Can you provide the link you downloaded, or the size?
The LabVIEW installation is two parts. First you install the industry version of LabVIEW from the DVD or a 5GB file. Then you install an update that is about 800MB. The update adds WPILib, RIO, vision, DS, and lots of other stuff.
Greg McKaskle
Unread 02-07-2015, 11:59
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
https://wpilib.screenstepslive.com/s...5-labview-only
This is the url for the instructions. They have the other links on it.3
Unread 02-07-2015, 13:21
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
I have the basic industry one at the moment, but the problem is it opened once, error coded, and the program hasn't opened or done anything since. I can't get it to open.
Unread 02-07-2015, 14:47
Do you remember what the error code was?
Be sure to reboot the laptop and try launching it again.
Then you will need to install the FRC 2015 Update, described here.
https://wpilib.screenstepslive.com/s...-all-languages
Greg McKaskle
Unread 02-07-2015, 17:36
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
I tried the restart and nothing changed. I don't remember the error code. I have the update suite it just hasn't downloaded anything yet.
Unread 03-07-2015, 10:11
Hmm. Well I haven't had that happen to me personally, and I'm not in the support group. I have a few more suggestions, and then I'd suggest we involve them.
Please try to launch it by right-clicking and running as Administrator.
If that doesn't work, go to Add-Remove Programs and do a repair.
Like I said, if you like, I can get a support engineer to call, since they have a database full of info that I don't know how to navigate. But they won't be available until Monday.
Greg McKaskle
