Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 07-07-2015, 11:45
Govind Girish Govind Girish is offline
FRC #2583
Govind Girish is on a distinguished road
Kinect with FRC?
Hello,
I'm a student lead for my team, and I was thinking of having some of our programmers try working with Microsoft Kinect.
I have some of them going through the documentation and setting things up. They were wondering if there is any recent material to help us through this. It seems like the only documentation for using Kinect with FRC was written in 2011-2012.
Thanks!
Unread 07-07-2015, 15:58
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: Kinect with FRC?
Originally Posted by Govind Girish View Post
Hello,
Thanks!
Kinect is a really cool technology. Were you planning on using it as an input to the driver station, or were you planning on mounting it on the robot and integrating it with your robot application software?
Also, note there are some technology limitations to be aware of if mounting the Kinect on the robot: the point cloud data has a max range of 13 ft (it's designed to be used in a living room around a TV, so it can't provide range data across the entire FRC field), and also that if multiple Kinect's are used, the point cloud algorithm on each can get confused if Kinect A picks up IR data transmitted by Kinect B. These may not be issues for you, but it's something to be aware of.
Unread 08-07-2015, 15:36
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
Rookie Year: 2012
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
they stopped using Kinects during auto mode in either 2013 or 2014, so that's probably the most recent documentation you can get...
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 08-07-2015, 16:00
FIMAlumni's Avatar
FIMAlumni FIMAlumni is offline
FIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura about
254 had the best use of a Kinect in 2012 at Championships.
Here is a video showing the highlights.
Unread 08-07-2015, 21:49
FRC #2583
I was hoping for it to pick up signals from the Human player. For example, in 2014 (Aerial Assist), if the Kinect could see the Human player make a certain gesture, it would fire.
At the very least, I wanted to have hot goal detection (which I'm pretty sure you can use without a Kinect, but for some reason I thought it would be easier with one). We're still working on this. If y'all could point me in the right direction regarding hot goal detection, I would be very grateful.
Unread 08-07-2015, 21:54
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
Rookie Year: 2014
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
For hot goal detection you could probably use a network camera that would have a higher resolution than the kinect.
Unread 08-07-2015, 21:56
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
I feel like this is the best Kinect implementation in 2012 at championships. (I know it isn't video of them at champs, but you get the point )
Related document
Unread 08-07-2015, 22:14
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Is it bad that I just start cracking up and I haven't even clicked the link yet? (I've seen the video before, mind you.)
Back on topic, orangelight is right. Particularly since this year, the use of Kinect was pretty much verboten during automode. (And given the blue box commenting on this fact, I would figure that it's safe to say that that particular use is not going to be back any time soon.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
