Go to Post FIRST is not really located in Manchester NH but with each student and mentor involved - UCGL_Guy [more]
Unread 08-07-2015, 09:51
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is online now
FRC #1756
Rookie Year: 2010
Bpk9p4 is on a distinguished road
Summer Labview Challenge 1
This week my labview class learned all about Boolean logic so this weeks challenge is all about Boolean logic. For this challenge you can only use Boolean logic. I highly recommend you only use AND, OR, and NOT. The challenge is based around a stoplight game you have a green, yellow and red lights. Your robot can be moving when the light is green it cannot be moving when the light is red. There are two parts to this challenge. Fell free to ask question and post your answer on here. I will post my answer to the problem on Tuesday.
Part 1
Your program will have 3 inputs and 2 outputs
Inputs
1) Green Light (True / False)
2) Yellow Light (True / False)
3) Red Light (True / False)
Outputs
1) Go (True / False)
2) Stop (True / False)
The challenge is to have Stop = True when the light is Yellow or Red and Go = True when the light is green.
Part 2
Your program will have 3 inputs and 3 outputs
Inputs
Outputs
3) Fault (True / False)
The challenge is the same as above however if more then one light is on Fault = True, Stop = True, and Go = False. The reason we are checking for faults is we always want to make sure you sensor is working correctly.
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
