| Thread Tools |
Rating:
Display Modes |
Stepper Motors
Do you think there's any chance we'll ever see steppers on the list of FRC-legal motors?
Open control loops are a whole lot easier than closed ones, and I've always felt steppers are a natural solution for a large portion of the FRC problem-space that is currently occupied by PID or bang-bang control loops. |
Re: Stepper Motors
This has been discussed before.
Steppers are really hard to use effectively, it would just widen the gap between the better engineering teams and the less experienced. It uses open loop control so if it loses steps they stay lost and can accumulate. In an FRC environment there are just too many opportunities to loose steps and it would likely end up being a nightmare for all but the best teams. An encoder versaplanetary stage accomplishes the same result in a more robust way without changing the rules. I've seen clever ways to attach encoders to versaplanetaries so even this isn't really necesary. (a half inch hex encoder would be cool though) |
Re: Stepper Motors
Combined with the above concerns (on missed counts), stepper motors are pretty awful in terms of power to weight.
Re: Stepper Motors
For many manipulators which require small, precise movements, I think a stepper is far easier to use than a DC motor in a closed control loop. Less complexity, fewer failure points. |
Re: Stepper Motors
Re: Stepper Motors
Electrical components become legal when enough of them are donated to FIRST to put an adequate amount of them in each kit of parts. If you want to use an electrical component, find a company willing to donate enough of them.
Re: Stepper Motors
I don't think that steppers should be restricted. If someone knowledgeable sees an opportunity to use one effectively than why not let them? It may just be hard to imagine how to use them in FRC simply because we haven't ever seen it.
Re: Stepper Motors
That doesn't mean that they aren't very well-suited for certain parts of it. Not all of FRC is lifting totes. |
Re: Stepper Motors
It also has the very real potential to be misused by less experienced teams and cause massive problems when it doesn't work properly. IMHO it's a can of worms that does not need to be opened. |
#10
Re: Stepper Motors
If I understand correctly, stepper motors require twice as many control signals as a brushed motor. So to save an encoder feedback you add another control circuit - with uncertainty if the torque isn't sufficient to make the step. It sounds like a step backwards, or at best sideways.
#11
Re: Stepper Motors
Re: Stepper Motors
#13
Re: Stepper Motors
I'd rather see the specs on allowable servos to be opened up.
#14
Re: Stepper Motors
On a related note anyone want a bag of discontinued throttle motors ![]() |
#15
Re: Stepper Motors
Now brushless motors in general... THAT would be a step forward. But steppers, in specific I don't think would be of much benefit to anyone.
Jason |
