Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 19-07-2015, 16:40
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
NXT/EV3 sensors with RoboRIO?
Hello all,
Is there a way available to connect a NXT or EV3 sensor to the RoboRIO. I know it was possible with the digital sidecar with the older cRIO. I was just wondering if there was a new way with the RoboRIO.
Thanks,
Joe
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 19-07-2015, 18:59
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: NXT/EV3 sensors with RoboRIO?
I have never tried any of this, but based on the communications protocols they use, it seems completely possible to use both NXT and EV3 sensors.
The digital NXT sensors (ie. ultrasonic) use I2C to communicate, likewise the NXT port on the digital sidecar was just connected to the I2C pins. I believe you would just need to make/modify a cable to connect the appropriate pins to the I2C port on the roboRIO and write a driver to communicate with it.
Some NXT and EV3 sensors (ie. light sensor) use analog signals to communicate. Using these should be as simple as connecting the correct pins to an analog input on the roboRIO and figuring out how to convert the voltage to a value.
The digital EV3 sensors use UART (serial) to communicate, so they can be connected to the UART port on the MXP (not the RS-232 port, at least not without a converter). Again, you would have to write a driver.
If you do any of this, the most important thing is to make sure you are supplying the right voltage to the right pins, to prevent damage to the sensors (the roboRIO is pretty well protected, so it would be fine with most mistakes).
These links might be helpful:
http://lechnology.com/2014/09/using-...-on-any-linux/
http://www.ev3dev.org/docs/sensors/
http://brweb.haltonrc.edu.on.ca/2022...ExtremeNXT.pdf (a lot of information)
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 19-07-2015, 20:39
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Is it necessary to use LEGO's sensors for your project?
Other companies, such as Sparkfun and Adafruit sell sensors that are likely cheaper, better quality and easier to interface to the RoboRIO through the analog or digital inputs.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 19-07-2015, 21:52
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
It's not necessary, but if we have them, it's cheaper than buying a new one :-)
Unread 19-07-2015, 21:53
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
These are great links! I was just curious if anyone has done it yet. (Or ever did do it with the Digital Sidecar)
Thanks!
