pic: 6in Butterfly Module With Piston
Looks pretty solid!
Re: pic: 6in Butterfly Module With Piston
might be nit picking here, but isn't a butterfly drive omni wheels as opposed to mecanum wheels?
If you put omnis on it then you're not going to get much utility out of it. Really, what do you gain from switching between traction and omni? You turn a bit better. That's about it.
However, if you have mecanum wheels, you can switch between having insane push power, to having a fast and holonomic drive. You get more utility out of it this way. |
Until you add a strafe module in the middle.
I'm not going to claim to be an expert on butterfly drive, but I wouldn't feel comfortable cantilevering that module out like it's a WCD, I'd rather support from both sides here. But then again I'm from the east coast...
Back on topic and not debating the pros/cons of butterfly vs. mecanum, I have to agree with pmangels somewhat that cantilevering the module sounds quite risky.
I think this would have to be paired with some bulletproof bumpers or an outside rail in order to work super well. That being said, I love what you're trying to do, and I really wanna see it work. Last edited by Kevin Leonard : 21-07-2015 at 12:50. |
#10
How are you going to manufacture the bracket for the cylinder? it looks dove tail joint I would use for wood drawers.
#11
See the Battlebot Bite Force's construction here |
#12
That piston mount plate might bend over time, particularly if there are bumpers contacting it (shoving can get them). We had a similar issue with bumpers in 2014, but it depends on where your bumpers are vertically.
#13
<Grumpy Old Man Rant>
It's a cylinder, not a piston! <end Rant> |
#14
same. However, to be fair to all "piston" people, if the piston wasn't there, the cylinder wouldn't work.
#15
Interesting module, I would also like to see how cantilevering it works out. Make sure you test that before the season starts if you plan on having it as a possibility. Last edited by Darkseer54 : 21-07-2015 at 20:40. Reason: Unhappy brother is unhappy. This is octocanum. |
