Go to Post Sounds fun? Maybe only if you're a giant dork, but I'm a pretty giant dork, so... - Madison [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 26-07-2015, 14:21
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rookie Year: 2014
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
Re: pic: Duodec-Drive (Octocanum)
Originally Posted by GarrettF2395 View Post
Also, does anyone know the thickness of the VexPro belts?
I defaulted to 0.1" because I couldn't find anything with that information.
SDP/SI has dimensions for 5mm HTD belts here. The entire thickness (including teeth) is 0.15". Teeth are 0.082".
Unread 26-07-2015, 15:26
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
One of the cool things about this kind of drive, if it has the right configuration, is you get suspension for your Mecannum wheels for free. This insures all four wheels are in contact with the ground at all times. This makes a difference when strafing. I'd suggest flipping your design around so it pivots on the solid wheel. You'll find the Mecannum wheels will work better if you do.
We used this kind of drive this year and in Bunnybots so got to measure this first-hand.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 26-07-2015, 22:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
If you change the design to articulate the Mecanum wheels, you shall be intentionally and regularly creating forces along the axes on a cantilever mounted on another cantilever whenever you're in Mecanum mode. Either you would have to "enclose" the module so that it's mounted on both sides, or beef up both cantilevers beyond what you'd need for the current design.
Mecanum without suspension is OK if the field is fairly flat and the chassis is slightly flexible (e.g. aluminum C-channel or square tubing). If you have a good bit of driver practice, the drivers can even get used to significantly uneven loading. Woody, our practice 'bot for 2014 Aerial Assist had only 13# on one corner wheel and about 50# on the opposite corner. We practiced with it on a patch of parking lot behind the stadium's concession stand; it was less than impeccably level. After a few hours driving, the operators had internalized the compensations. It did take a couple of practice matches indoors with "Buzz", the competition 'bot, to unlearn those compensations. (Yes, Woody actually had a 2-by-4 wooden chassis and kicker and 2-by-2 pickup arms - video of driver practice here. We decided that the practice 'bot would be different than the prototype(s) and much more like the competition 'bot in 2015.)
