Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
Unread 28-07-2015, 11:08
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
pic: FRC3928 2013 Butterfly Module
Unread 28-07-2015, 11:09
Dylan179's Avatar
Dylan179 Dylan179 is offline
FRC #0179 (Children of the Swamp)
Dylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud of
Re: pic: FRC3928 2013 Butterfly Module
what kind of hub did you use for the traction wheel?
Unread 28-07-2015, 11:44
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Since your cylinder mount doesn't pivot, could you go into some detail about how you attach the cylinder to the module?
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 28-07-2015, 11:51
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
It just pushes on a standoff. There is some sideways sliding contact but it's a non-issue.
Unread 28-07-2015, 12:49
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
Rookie Year: 2011
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
If you're having trouble visualizing, you can check out this video of 3847's modules from 2014:
https://www.youtube.com/watch?v=GF_CP-9eMDY
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 28-07-2015, 16:54
pmangels17's Avatar
AKA: Paul Mangels
Rookie Year: 2011
Ah, that does seem like the simplest solution. Thanks!
Unread 28-07-2015, 23:16
Aren_Hill's Avatar
Build Nifty Things
In this instance the traction wheel was made from a solid piece of 2.5" diameter Delrin, the Pulley was milled into the side, and two 3/8" bearings were pressed into it.
Had access to a CNC mill, decided to minimize the part count and not require ordering a pulley.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 29-07-2015, 16:14
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
And now I know where Adam got his 2013 offseason drivetrain design.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 01-08-2015, 20:54
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2013
kitare102 is an unknown quantity at this point
What would someone look for if they were trying to find an extrusion like you guys used for the main structure of these rails? As well, how are you planning to connect the frame up once both side rails are completed? The pattern of those holes looks like it would be great for designing attachment points.
Unread 03-08-2015, 21:50
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
As this was our 2013 robot, you can see how the frame was designed to be assembled here.
Unread 03-08-2015, 21:58
Aren_Hill's Avatar
Build Nifty Things
Also for reference this is 3"x3" x .125" wall Aluminum tubing, nothing special.
Online metals has it but a local supplier will give a better price.
-Aren
