Go to Post The only thing a team needs to survive is people who want it to survive. - Ryan Foley [more]
  #16   Spotlight this post!
Unread 29-07-2015, 18:09
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: General Motor Rules
Originally Posted by Kevin Leonard View Post
...but in 2015 we had to make a total of zero trade-offs when it came to alotting motors. 20's elevator had 4 motors on it, for example.
Exactly why I agree with EricH about having stricter motor limits. Having to make significant tradeoffs in how much power to allocate to what mechanism is a fun part of design and encourages creative solutions vs. lets just throw more motors on it until it does what we want.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #17   Spotlight this post!
Unread 29-07-2015, 18:14
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
I think requiring 12V motors isn't a good idea. The RS-775 everyone uses is an 18V motor, and it runs great, partially because its never running more then 66% of what its rated for. I think the watt and amp limits need to be counted at 12V, but if you want to use a motor rated for higher voltage you should be able to do so. The battery already limits to 12V.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
  #18   Spotlight this post!
Unread 29-07-2015, 18:33
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Originally Posted by Michael Hill View Post
I'm curious, is there some written standard for 500/700 series motors? All I've found are actual Mabuchi part numbers as well as other motors claiming to be 500/700 series motors for RC toys. (Or did Mabuchi just set the standard?)
Originally Posted by AdamHeard View Post
I've never sought one out, but i'm sure it exists.
I did some digging and wasn't able to find a comprehensive standard that covered any given series of Mabuchi motor, but it looks like it'd be simple enough to allow any motor with a Mabuchi part number of of "RS-3XX", ,RS-5XX" or "RS7XX" to be used in FRC, since we've already seen these motors in the KOP (virtual KOP?) at least once.
Personally, and this is only my opinion, the motor rules as currently written, and previously written (at least as long as I've been in FRC) - dont work. I've seen at least two or three robots a season - usually at events where you've got a lot of "one and done" teams, that use illegal motors, usually something from a previous KOP.
I honestly can only think of one time where any inspector ever cared about motors to the point where they checked part numbers, and that was back in 09 - there were three or four RS500 motors at could be used... (Only one of them made sense... We did not use that one) so the inspectors knew to verifying part numbers.
We're almost at a cross road, either limit the motor rules, specifically to CIMs, Mini-CIMs, Bags, 500 cans (AM-9015?) and 700's (AM PG series?). At that point, between the visual uniqueness of the CIM family compared to most other motors, it's hard to mistake one motor for another, and AM has a colorful enough label that it jumps out. (Although RS775-18's are awesome, someone make a colorful label.)
The alternative would be to limit max power win an open(ish) motor list. I think this actually may solve the problem, at least for the most part - but you still run into instances where the same motor may have different specs depending on the vendor - not to mention that you'll have a handful of teams ripping apart drills and other tools to pull motors out, with no real way of verifying the specs.
IMO, in a perfect world, motor allotment is any combination of CIM's, Mini-CIM's, BAGs and RS-series motors under a total of ~3.5-4kw of power. After that point, if you're really using all of that, your batteries will rarely last a match, which creates more problems than it solves, obviously. It also forces teams to make smart decisions about where to use power and where not, rather than the current "all CIM everything". (Although a 3.5kw cap does not prevent one from doing all CIM everything, it just limits what they can do with that mentality.)
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #19   Spotlight this post!
Unread 29-07-2015, 18:40
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
I think we should just use all Mini CIMs and BAG motors.
There will be those that get the joke and those that do not ...
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #20   Spotlight this post!
Unread 29-07-2015, 20:40
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You mean IFI hasn't developed a 700-series motor yet? Or a BIG CIM? Seriously?
Yep, I get the joke.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #21   Spotlight this post!
Unread 29-07-2015, 21:48
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Good idea. And smoking motors should be an automatic yellow card.
Richard Wallace
since 2003
  #22   Spotlight this post!
Unread 29-07-2015, 22:32
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
Originally Posted by EricH View Post
Seriously, folks. If the motor selection currently available doesn't fit your needs, you may want to reconsider how you're doing things. Try pneumatics.
Originally Posted by IndySam View Post
Amen, teams have way to many powerful motors now. We need to get back to the days of having to make decisions about where to use the most powerful motors. I miss this design challenge.
I couldn't agree more. My personal preference would be 5 CIM motors (can be freely downgraded to minis), 3 minis (plus downgraded full ones), 5 combined RS/bag/PG motors and unlimited auto motors.
It would also be interesting to see a year with a very strict motor allowance. 3 cims, 4 minis, 4 combined RS/bag/PG motors and unlimited auto motors for example.
What I really think we need is a CHEAP motor controller for the smaller motors. You don't need to withstand 100+ amps of surge current for a window motor. It would also give some much needed utility to these motors.
I inspected a team which used 1 speed controller for 2 cims. It was a bad mistake but it just goes to show that we don't need more complex rules. On that note: open up the servo restrictions.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
  #23   Spotlight this post!
Unread 29-07-2015, 22:51
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
THAT one, I'll go for. 4W is pretty weak.
I'd say to allow all micro-servos, and any hobby servos up to some reasonable wattage (10W, maybe? 20? Just throwing some numbers out here...), but nothing that isn't a hobby servo (AKA, nothing industrial).
Past teams:
  #24   Spotlight this post!
Unread 29-07-2015, 23:30
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
The point was not to increase the arbitrary power limit but to limit the power by setting a direct limit on power. Right now the limit is indirectly set by specifying how many of each specific motor a robot can have. I am proposing that either it be set by a total watt limit, a categorical watt limit (see op), or similar method. The limits in the first post can simply be reduced to satisfy a reduced power allowance.
In short the point was to increase the number of different motors we could use not the total wattage of what can legally be attached to the robot.
Edit: I too would like to see an increase in both the servo and solenoid wattage limits.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
  #25   Spotlight this post!
Unread 29-07-2015, 23:48
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Why? Really simply, why? What exactly is the current motor restriction not allowing you to do that you need to do?
Is it just that you want to use a different motor? OK, submit the idea to FIRST to see if they can get the company interested in supplying 3K motor "sets" (a set being anywhere from 1 to infinity motors). A different type of motor altogether? In that case, I ask why you really need that functionality, and look for workarounds. Or is there something I'm not seeing? (I honestly don't see any application for stepper or brushless motors that can't be handled with an additional sensor on the robot and careful motor selection.)
In the real world, the customer doesn't relax requirements just because "it should be this way". The customer only relaxes the requirements if it can be conclusively shown to their satisfaction that the requirements must be relaxed in order to meet other requirements--and usually, that can't be shown! Again, FIRST imitates life...
Now, I bet someone is going to come back with "well why do you favor the servo limits increasing?" And my answer is that it is nearly impossible for teams that don't want to use pneumatics to have multiple speed drivetrains with the servos we have. I've seen teams gang servos to get the required power for some relatively minor jobs. I've very, very rarely seen a servo used on a robot--a "gate latch" a few years ago being one of the cases. Plain and simple, there just isn't enough power available in that group.
Past teams:
  #26   Spotlight this post!
Unread 30-07-2015, 10:23
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Full disclaimer: I am not a robot inspector, nor have I ever been, but I have been at all of my teams robot inspections from 2011-2014, and I feel that that qualifies me to say what I'm about to say, which has already been echoed in this thread.
Why are we going to make the inspectors' jobs more difficult? Any team that cannot accomplish what they want to build with the motors currently available has bigger issues that the available motor selections. Any team that is going to gain a slight performance boost from some obscure motor somewhere probably already soars above the competition with regard to whatever they are trying to improve.
So, back to the big question, why make inspections harder? Every interaction I've had with an inspector has led me to the conclusion that they are there to make sure that our robot gets on the field and doesn't explode/hurt people/break other robots with fire/anger insurance agents, and THEY ARE THERE FIRST AND FOREMOST TO HELP. Opening up the motor rules would require teams to bring in documentation and prove that their motors are indeed what they claim they are (with data sheets, etc, that teams will inevitably forget to provide). On top of that is the problem that motor spec sheets don't always have accurate data in the first place (BaneBot 550), so now inspectors have to judge whether those high school kids with the wire birdsnest plugging in random motors they found on eBay that draw 100+ amps of current are safe and within the confines of the rules. Rules, I might add, that solved a problem that didn't exist in the first place.
So, in short, opening up motor the allotment solves a problem that doesn't exist and creates unnecessary headaches for volunteers that already have a lot of stuff on their plate, all while lengthening the inspection process, and in the process slowing down the teams that followed rules to the T and now want to get on the field on practice day.
My vote would be, go back to the motor rules we had in 2011. There were enough motors there to do whatever we wanted, not enough for a drivetrain arms race, and just enough limitation that teams were forced to make tradeoffs on design. For posterity, those rules were: 4 CIM's (we could say now and/or MiniCIM's), 4 Banebots, FisherPrice Motors from the KOP, window motors from the KOP, and maybe now a couple AndyMark or BAG motors
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #27   Spotlight this post!
Unread 30-07-2015, 12:03
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Similar motor rules to 2011 makes a lot of sense.
4 CIMs, 2 MiniCIMs, 4-6 BAGs/Banebots/AM/Fisher Price, Unlimited Window motors/Servos
If you need more motors than that, I don't know what to say. (20's 2015 robot had 12 motors on it: 4 CIMs, 6 BAGs, and 2 window motors. The original version of it had 4 CIMs and 8 BAGs, but without the window motors)
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
  #28   Spotlight this post!
Unread 30-07-2015, 12:08
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
I'd like to see more than 4-6 BAG/BaneBots/AM motors, but more strict CIM and miniCIM restrictions would be appreciated. Unlimited miniCIMs is just absurd.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #29   Spotlight this post!
Unread 30-07-2015, 12:18
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Why?
  #30   Spotlight this post!
Unread 30-07-2015, 12:19
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
The proposal to open up 500 and 700 sized motors makes it easier for inspectors.
Does it look like a 500 or 700? Well it's most likely legal.
