Go to Post Michigan teams will eat your souls. You have been warned. - MishraArtificer [more]
Unread 05-08-2015, 15:28
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
pic: WCD Butterfly Module
Unread 05-08-2015, 15:30
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
Rookie Year: 2012
jagoldman is an unknown quantity at this point
Re: pic: WCD Butterfly Module
That's a really cool design. What is the weight of the chasses? Also when you have the high friction wheels down are the Omni wheels touching the ground?
Unread 05-08-2015, 15:40
Flywheel Police
I don't have weight numbers at this point. The chassis itself is one we developed last summer and used this past season. So the only added weight would be the modules themselves.
In this configuration the omni wheels are allowed to ride along on the ground. Adding a spring to pull them up, if this was undesirable, would be a very easy addition.
Unread 05-08-2015, 15:44
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Since they're geared 1:1 I doubt it'd matter too much if they rode on the ground. They'd have next to no normal force anyway.
Unread 05-08-2015, 15:45
Flywheel Police
Agreed, which is why the option was not added currently. My only worry is carrying the robot, they might have a tendency to want to swing down. The pneumatic tubing might keep this from happening though.
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Very cool design. The use of the front rail as a brace for the piston is a bold idea.
I noticed that the drive chain will have to run from the center gearbox all the way to the corner so that it isn't on the pivoting sprocket (with a changing C-C distance). But if it does that, then the chain goes through the pivoting sprocket. You might want to make the pivot point the sprocket that's closer to the chassis to avoid this issue.
<Now accepting CAD requests and commissions>
Unread 05-08-2015, 15:47
Flywheel Police
This is actually a chain in tube chassis, the chain run is identical to our chassis without the modules on it.
Unread 18-11-2015, 11:53
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
I really like this approach on how to make a WCD Butterfly drive!
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
