Go to Post Good drivers know the limits of their machines, but great drivers have machines with no limits. - sanddrag [more]
Unread 14-08-2015, 19:36
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Gearbox Design Feedback
The way your standoffs are supported, they're almost cantilevered off the main body of the gearbox for the left and right ones. You are also using 6 standoffs versus the traditional 4, any particular reason for that? Removing the leftmost and rightmost standoffs would simplify it a little.
I think you have 2-4 too many pockets, but proper build season planning can offset the machine time in the case of a drive gearbox.
<Now accepting CAD requests and commissions>
Unread 15-08-2015, 13:30
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Yeah I agree. Next time I'll work on keeping things closer to the bulk of the body, or just put a ring around everything. I put these extra standoffs as support for the cims, but I realize that a whole another set of standoffs is unnecessary.
I personally don't think that pockets are a time problem for machining, as a water jet or CNC mill would zip right through them in a matter of minutes. But I will definitely work on simplifying the structure a bit more.
Unread 15-08-2015, 13:26
Team Role: CAD
Rookie Year: 2015
Originally Posted by Richard Wallace View Post
My team has been retaining things on hex shafts by means of 1/4-20 button head cap screws and standard washers at each end. Thunderhex shaft stock makes this method very easy, because its center hole is just right for the tap. We often drive the shaft using a 1/2 inch speed wrench while holding the tap stationary. Of course this method requires us to cut shafts very close the proper length to hold whatever components are riding on them -- we use a scribe to mark them and a small lathe to face them for that.
We do that too but just for backup in case the snap rings fail. Its definitely a neat technique.
Unread 15-08-2015, 13:24
Team Role: CAD
Rookie Year: 2015
Originally Posted by hectorcastillo View Post
The design looks really cool! One thing that I thought of is you could add two or three #8 tapped holes in a circle around the front bearing and use some button head screws to hold your bearing in place instead of a retaining ring.
That's a really interesting idea. I ended up just reversing the bearing to eliminate the problem altogether.
Unread 15-08-2015, 13:23
Team Role: CAD
Rookie Year: 2015
Originally Posted by Ari423 View Post
From what I can see, the two screws holding in the CIMs are accessible from the outside. One screw looks to be the top standoff screw, and there is a hole (in line with top and bottom standoffs, below CIM output shaft) to unscrew the other screw. Then it should be as simple as popping off the CIM gear and sliding it out of the enclosure. I could be wrong, but I imagine this was SerpentEagle's intent when designing it.
This is a nice, compact gearbox. How much does it weigh? Also, did you think about the abundance of possible pinch points where someone could get a finger stuck? I imagine it shouldn't be that hard to cover with some clear plastic (which will also help keep out scruff) but maybe you have a better idea.
No your right, that was the intent.
According to solidworks it weights approx. 6.5 lbs, so ~7 lbs.
And no I didn't think about pinch points, good thing you brought it up. I'm thinking that a 3d printed shell with screw holes would work nicely.
Unread 15-08-2015, 13:19
Team Role: CAD
Rookie Year: 2015
Originally Posted by T^2 View Post
You're gonna have a hell of a time taking those CIMs off without disassembling the entire gearbox.
Standoffs do not need to be 1/2". You have too many of them, in any case; the ones on the far right and left are completely unnecessary.
Not really. The bottom two screws are externally accessible, and only the top two are combined with standoffs.
Im a bit confused with the standoffs. I've never had experience with these kinds of gearboxes. I see respected teams such as 254 use some pretty large standoffs, and some teams use smaller ones. Would there be any issues with rocking if the standoffs are too small?
And I agree the left and right standoffs are unnecessary, I've made changes accordingly.
