Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Unread 15-08-2015, 16:24
RoboticDaymon's Avatar
RoboticDaymon RoboticDaymon is offline
AKA: Daymon W.
FRC #2403 (Plasma Robotics)
Rookie Year: 2013
RoboticDaymon is an unknown quantity at this point
pic: Butterfly Drive Concept
Unread 15-08-2015, 16:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: Butterfly Drive Concept
Wouldn't this be like an actuatable slide drive due to the center wheel? I thought butterfly didn't implement that.
50lbs is a lot for a drivebase. Do you really need those upper supports? It also looks like you're running a 7-cim drivetrain right now, which I'm not sure you need.
I like the design of the modules. I think they're missing a few spacers on the screws though.
That cylinder setup is not the most efficient because of the sharp angle it pushes the module down at. Is it possible to use a shorter cylinder that's more above the module so that it points almost downwards?
<Now accepting CAD requests and commissions>
Unread 15-08-2015, 16:53
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
The addition of the slide drive is cool, but I think the extra wheel in the center is unnecessary - you'll should be just fine using a single wheel in the middle. I have a feeling you'll also need to increase the motor count in the center if you want an appreciable speed for your sliding - going down to 2 CIMs per shifter and 2 cims in the middle should give you a pretty good balance. That should also reduce your weight a little - as mentioned above, 50 lbs is a lot for a drivetrain. I figure you should aim to be in the ballpark of 25 - 35 lbs for most drivetrains in FRC. That said, that estimate does seem a little high. Make sure you have the proper weights assigned for the various motors (override part weights), and the correct materials for the tubing / plates. You might also be able to reduce the thickness of your tubing - while I can't quite see what thickness the tubing is, you might want to consider using something in the range of 1/16 - .09" tubing.
Speaking of the plates - those plates look a little too pocketed, and I'd be seriously concerned about their rigidity.
Unread 15-08-2015, 18:46
hectorcastillo's Avatar
hectorcastillo hectorcastillo is online now
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
Rookie Year: 2011
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
It looks like the two center wheels are part of a tipping kicker wheel that applies a force into the ground when it tips. We used this design this year, and it worked out pretty well for us.
I would suggest supporting all of your wheel modules on both side, instead of cantilevering them on one side.
Another thing that I noticed is that if you break a belt on your drive train, you have to literally disassemble the frame in order to put another belt on. You definitely want to figure out a way to make replacing belts easier and actually possible.
You should also consider swapping the positions of your wheels so that the modules pivot off of your traction wheels. Last summer I designed a drivetrain very similar to this one with the same wheel configuration, but one of my mentors pointed out that you're going to be hitting and pushing against people primarily with your traction wheels and the resulting contact might damage the modules in the current configuration. If you swap them, most of the energy will go into the stronger frame which is what you want.
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 15-08-2015, 19:39
AKA: Daymon W.
Rookie Year: 2013
In response to the belt breaking I had thought about that which is why that is actually #25 chain. And yes decadrive is the proper name (thank you I couldn't remember what it was called).
Last edited by RoboticDaymon : 15-08-2015 at 19:59. Reason: additional information
Unread 15-08-2015, 20:58
Rookie Year: 2010
Ah, gotcha. While I can see how that design will make it so that only one of the two wheels is on the ground when turning, did you guys have a mechanism in place to balance the module when the motor wasn't turning (some sort of spring return, maybe?), or was that not necessary to keep both wheels off the ground?
I also see that your design from this year used a single CIM motor on the slide - what lateral speed were you guys capable of with that?
Unread 15-08-2015, 23:48
Rookie Year: 2011
Although we thought about having some way to return the module to its level position (mechanical or code), we found that it was necessary. In addition, we found that we needed to keep the module from tilting with gravity to reduce "hopping", basically when the module hits the ground but can't get traction and causes the whole robot to jump up a little. We solved this problem with a ramp up in the code and a friction plate that we would tighten in place made out of a VersaHub and gum rubber.
Ah yes, after taking a closer look, I saw that it's chain. Haha sorry about that
Unread 15-08-2015, 22:28
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
It looks like it uses chain, not belt.
+1 on making it pivot around the traction wheel, although I would want to for the suspension effect as well.
Unread 15-08-2015, 23:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
It appears as if it pivots on the omniwheels. I'd have some concern about the load the traction wheels will apply to the pivot axle when the machine is pushed sideways.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 15-08-2015, 17:02
AKA: Daymon W.
Rookie Year: 2013
Naming it an actuatable slide drive would probably be more accurate, I hadn't thought of that. I called it a butterfly due to the shifting of the wheel modules.
I know 50lbs is a lot for a drive base and I've been working on lightening it. The upper supports are there for bumper mounting purposes but I will probably work on revising it by maybe removing the front and back rails.
Yes 7 cim is overkill if I were to actually build it I would almost certainly just use 2 cims in each gear box and a minicim for the center (depending on game)
As for cylinders I'm trying to design to take advantage of some 3/4 inch throw that were bought for last season but never used. So the cylinders in the CAD are just place holders. I can edit the design to change where the cylinders are placed.
The extra wheel in the center is to make it function so that the wheels would dig into the ground when they are powered. This is so the wheels still have contact on slightly uneven surfaces.
I checked through the weights in inventor and I'm fairly sure there all assigned right.
The tubing is versa frame which is already .1 inch wall.
The plates might be pocket a little much I will probably change that for the next revision.
Unread 15-08-2015, 18:30
wilful's Avatar
wilful wilful is offline
766 Alum &amp;amp; 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
what you have here is a nonodrive (i think thats how its spelled). Anyways check out 148's 2014 drive system, which seems to be the inspiration for this.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 15-08-2015, 18:49
Rookie Year: 2011
I believe that this particular design is called a decadrive because it has 10 wheels. A nonadrive is very similar, but there is only one center wheel giving a total of 9.
Unread 15-08-2015, 22:17
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Personally I'm a fan of the name butterslide drive
Unread 15-08-2015, 23:56
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Perhaps you can explain because I have never seen a drivetrain like this before. What are the advantages of this over octocanum? Based on the picture and description it looks heavier, more complex, uses more motors, and is harder to build than an octocanum equivalent. I'm sure I must be missing something or someone else would have brought this up earlier, but I don't see it.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
  #15   Spotlight this post!
Unread 16-08-2015, 00:12
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
With Mecanum you have to run each wheel individually. Here they can run each side resulting in the ability to run 3 cims per side.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
