Go to Post Who cares about the score? The score is just numbers on a board, the exciting part is watching the robots interact and seeing robots( and more importantly, people) do the impossible. - Herodotus [more]
  #31   Spotlight this post!
Unread 20-10-2015, 12:26
hank2247's Avatar
hank2247 hank2247 is offline
FRC #4388 (Ridgebotics)
Team Role: Mechanical
Rookie Year: 2012
hank2247 will become famous soon enough
Re: spud gun/T-shirt gun valve
the sprinkler solenoids are rated for 150 psi
  #32   Spotlight this post!
Unread 20-10-2015, 13:18
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
150PSI gas?
Sprinkler valves are generally only rated for liquids.
P.S. It's the valve portion, not the solenoid that's rated for pressure
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #33   Spotlight this post!
Unread 20-10-2015, 14:28
hank2247's Avatar
Rookie Year: 2012
Originally Posted by Daniel_LaFleur View Post
150PSI gas?
Sorry I meant the valve not the solenoid.
I'm not sure if it was rated for gas and liquid but i know it was 150PSI.
Either way it should have the same chance of failing regardless of Air/Liquid. It's just that if it fails with air the results will be much worse.
  #34   Spotlight this post!
Unread 20-10-2015, 14:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Compressed air has more energy than compressed liquid. You want to use a valve that's specifically rated for compressed air.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
  #35   Spotlight this post!
Unread 20-10-2015, 16:10
hank2247's Avatar
Rookie Year: 2012
Compressed gas does have more energy than compressed liquid, but the force exerted on the valve is the same. Pressure is pressure, air just compresses significantly more than liquid so its potential energy under pressure is much greater.
  #36   Spotlight this post!
Unread 22-10-2015, 08:55
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
precisely. That's the part of this discussion that convinced me (and my teammates) that continuing to use a sprinkler valve was a Bad Idea™.
