Re: [FRC Blog] Frank Answers Friday: Championship Slots
And most of the times judges don't get to watch many of the matches. |
Agreed. I wasn't criticizing the people, it's just that the process isn't currently setup to identify the best robots (as that's not the current goal of the process). Identifying the best robot would require a large shift, or addition of more judges, to allow substantial match view time by more than a single judge or two.
And I just said "That's the point." Having judges do what they do isn't about objectively determining who the "Innovation in Controls" award winner should be- it's about exposing industry leaders who are often judges to these amazing students and exposing these students to industry leaders. Ex: I talk to Team A and Team B, and Team A's students tell me in detail about their sloppy control system for their mechanism, while Team B wins the regional with their tightly and highly controlled mechanism but can't discuss it with the judges. I, as an FRC person who understands what these students are doing, might still award the award to the winning team, whereas an outsider judge will award it to the team who can talk about what they built better. That is (I think) an intentional part of the system. I place more focus on results, whereas a non-FRC person will place more emphasis on the attempt and the innovation than the results, while also learning about what FIRST-er's do. I think the main problem with the regional system is when finalists aren't invited to championships or when the second best robot at an event loses in the semifinals because they were on the wrong side of the bracket or something. What if (bold idea), before week 7, FIRST polls a number of experts on who the best 20 or so teams to not make championships are (kind of like this, but two weeks earlier) and invites them to the championship event. |
Maybe your saying make the Excellence In Engineering award qualify a robot to worlds too? |
Why isn't there? The district point system can be adopted to a single event format easily, in order to give points to teams at that event based on robot and award performance. |
In a fairly large amount of cases, this would just qualify the first two robots on the winning and finalist alliances. Right now, a massive chunk of points come from getting picked high and going far. Culture changing awards points would need to be rebalanced to work in a single event format. Someone could run numbers and see how things would pan out.
Code:
Points Team Selection Finish Awards 73 303 1 Capt W Winner, Inn. in Cont. 72 2590 1 First W Winner, Entr. 60 11 2 Capt F Finalist, Judges' 51 193 2 First F Finalist 48 4285 3 Capt SF Exc in Eng 46 1923 5 First SF Chairman's 46 25 3 First SF Creativity 46 3340 1 Second W Winner 44 869 5 Capt SF Quality 43 1257 2 Second F Finalist, Spirit, Safety 36 4954 4 Capt QF Ind Des 33 5666 5 Second SF RAS 33 3314 7 Capt SF EI 31 219 4 First QF ... Winners: 303 (prequalified, Mount Olive Chairman's), 2590 (Montreal Winner), 3340 CA: 1923 (prequalified, TVR EI) EI: 3314 RAS: 5666 Generating 3 wild cards: Current System: 11, 193, 1257 District points: 11, 193, 4285 Looking at the OPR for that event, 4285 averaged ~43 points per match, and 1257 ~21 points per match. Using district points for wildcards sends a slightly different but more competitive set of teams to CMP. |
A couple of comments:
1. One of the most striking issues I find is that no one has mentioned the problem of awarding Championship slots to districts based on their proportion of the FRC population in a post-Championsplit world. Using 2015 figures, and assuming them to remain constant for this discussion, Michigan (not picking on MI, just the easiest to make the point) teams comprised 11.86% of registered FRC teams which corresponds to roughly 71 slots for St. Louis. The same should hold true for 2016. However, beginning in 2017, Michigan's 345 teams will represent either 11.86% of the overall FRC teams or 23.73% of the corresponding Championsplit pool. Given that both Championsplit venues will host 400 FRC teams, will Michigan teams comprise 47 slots or 95? Clearly, something has to change with respect to the awarding of Championship slots on a proportional basis to district participants. 2. I have posted previously about the need for there to be a single set of consistent and fair qualification criteria for Championships. This post by BMSOTM looks like a potential solution, (assuming a return to W-L-T). The district point system has always served as a comprehensive way of separating wheat from chaff and advancing quality teams to Championships. Quote:
Glad to see Frank is keeping an open mind on this issue as I believe the application of a district scoring model to the FRC population as a whole is a potential solution rather than a complicating factor. In 2015, we implemented average scores. Could apply the same methodology to account for teams attending 1 or more events with the top 400 teams advancing to their corresponding Championsplit venue. On the minus side, teams near the cut-off point face uncertainty in the closing weeks of the season but how does that differ from the current system used by districts? Such a change would not necessarily address under-representation of geographic areas at Championships but would level the playing field to the greatest extent possible. Last edited by mwmac : 02-09-2015 at 22:05. |
#10
Thank you for catching my error. I have corrected my figures in the post using 2908 as registered team head count (http://www.chiefdelphi.com/forums/sh...tration+201 5) and 345 as Michigan team count (https://my.usfirst.org/myarea/index....250#FRC_teams).
The issue is still significant for the allocation of post-Championsplit district slots for their corresponding venues. Just the spread is now 47 to 95 slots in the case of Michigan. |
#12
