Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 08-29-2015, 08:34 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
6wd tank with 2 omnis?
Does anyone have experience with 6wd tank style drive bases, using 2 omnis on the front (and 4 tractions on the other)? I'm thinking this could be a good configuration for defense heavy games. The benefit would be almost all of the traction of a conventiinal 6wd (especially in fwd), but with faster turning and no rocking from a drop center. The downside is unsymmetrical handling going forwards and reverse, and reduced traction when in reverse.
I'm tempted to build a test base in the pre-season, but would love to hear other's experience first.
Unread 08-29-2015, 09:28 PM
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: 6wd tank with 2 omnis?
In 2014, 1625 used a 4wd with 2 omnis/2 traction wheels allowing them to spin quickly and fly around the field yet still push effectively.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 08-29-2015, 09:35 PM
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
We used the 2 omni, 2 traction setup this year (as did *many* others), but we didn't have to think too hard about pushing power in Recycle Rush. Thanks for that match video though - it seems like 1625 had no problem keeping up with a similar configuration in 2014.
Unread 08-29-2015, 09:36 PM
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
Rookie Year: 2012
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
I haven't ever heard of a team doing this, although from experience, there is not much shake from a drop center wheel on tank drive (my team has only ever not done tank once). if that really worries you, just use 5 wheels per side, like 2046 did in 2012
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 08-29-2015, 09:42 PM
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
While you are correct that 1625 was very successful with a similar drive setup the match you linked may be a little deceiving. The team they are pushing around, 33, had only omni wheels on their drive train so they were very easily pushed around by defense.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 08-29-2015, 10:02 PM
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Do you have some pics/more info? I'm curious.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 08-29-2015, 10:20 PM
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
Team Role: Mechanical
Rookie Year: 2013
kitare102 is an unknown quantity at this point
3042 used a 6w WCD this year, and were having enough problems with brownouts due to our long wheelbase that we decided to switch the two back wheels to omnis. This is obviously not the same as your suggestion, as going forward we didn't get the traction of 4 standard wheels, but I can speak to the stability and maneuverability of the 2 omni, 4 traction wheel concept as a whole. definitely helps turning ability when dealing with tight corners and cramped conditions, so I would be confident in this setup's viability for getting around defenders. That being said, nothing provides better evidence that real-world testing, so I might suggest trying our some omnis on an old 6w drivetrain if possible.
Attached is a good view of our 2015 drivetrain to show what our setup looks like.
Unread 08-29-2015, 11:18 PM
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
Rookie Year: 2010
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
We tested this on our 2015 bot during build season with the same idea that it would cut our turn speed in half. It turned out to be a nuisance because our robot holds totes out in front resulting in the robot leaning forward because of the dropped center. The omni wheels in the front resulted in the inability to move as effectively as we could before with belt driven wheels.
2014 Gateway Robotics Challenge Winners with 1985 and 2481
FRC IS LIFE
Robolions 3397 pages
facebook- https://www.facebook.com/robolions3397
youtube- https://www.youtube.com/user/robolions3397
Instagram- @robolions_3397, https://instagram.com/robolions_3397/
Unread 08-29-2015, 11:24 PM
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
862 has done a 4x traction-wheel, 2x omni-wheel drive with no drop in 2012 and 2013. From what I have seen on the field and heard from the co-driver of those bots, it has worked out well for them.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 08-30-2015, 03:24 AM
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Wide or long? 5188 did this with a 38" long frame. We the omni pair on the front and the back and both had trouble turning. We ended up going for center traction (Colsons) and 4 outside omnis.
Make sure you get a lot of drive practice with this setup if you want to use it in a higher speed game with defense. If driven well, it is very useful for getting around defenders. However, with the few minutes of drive time I had on 469's 2012 robot (front ball casters, back pneumatic wheels), turning to a specific angle becomes difficult, you need to compensate for the robots momentum by applying a bit of power in the opposite direction to spin to a specific angle.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 08-30-2015, 03:56 AM
Rookie Year: 2012
ugh I dont think I have any pictures of it at this point :/ been too long. there's some old video here: http://www.thebluealliance.com/team/2046/2012 and you might be able to see it up close there.
As to why we did it; Story time!
So, way back in 2012, we decided one of the key things was going to be field mobility: getting over the bridge and bump easily. however, we also wanted our robot to be as wide as possible, both to give us the widest possible collection area, and to make balancing easier. having a wider drive base and having a lot of weight up high (due to turrets) makes a robot tend to tip when going over a bump. my former team was and is exceedingly neurotic about tipping, and wanted to avoid it at all costs. that meant keeping our weight as low as possible (hence our turret at the bottom of the shooter tower), and, more importantly to what I'm actually trying to tell you, having as long of a wheel base as physically possible.
with a larger wheel, there would have been a shorter distance between the front and back wheel, which would make it harder to get over the bump. so we wanted small wheels. but that would cause us to high center in the middle of the bump, so we needed them along the full length of the robot. we could have done treads, but we had no experience with them, and man are they hard to do properly. turns out we needed 5 wheels on each side to make that work properly.
tbh, the multitude of wheels we had is rarely necessary, unless there is some sort of field barrier. But, at least in my experience, having lots of small wheels makes the effects of the drop center less profound. now that being said, we didnt use tank this year (H-drive instead), so I dont know how it affects lifts.
Edit: found some pictures that kinda show it
https://www.facebook.com/washingtonf...e=1&permPage=1
https://scontent.fsnc1-1.fna.fbcdn.n...3d&oe=566793A3
FRC 2046 2012-2015
Unread 02-25-2016, 08:31 PM
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
We have two 10 in pneumatics in the front, 6 in colsons in the middle, and 8 in omnis in the back.
oops didnt realize i was browsing in search sorry for the bump haha
