Re: Bearings vs Bearing Blocks
The pillow block style can be mounted below the frame so you have more floor to frame clearance with the same diameter wheel. |
This may be a confusing explaination and I don't have any pictures from home, but if anyone is interested I can try to explain in more detail and get pictures the next time I'm in the shop. |
We use bearing blocks for slots or other moving connections. Otherwise we just use plates with mounting holes, or bore directly into aluminum box tubing when it's applicable.
It really depends on the application. We generally aim for a 1.124" or 1.123" hole (the latter for undersized measurements on bearings) by boring it out on the Bridgeport mill, manually. It's arduous but generally only takes around 5-6 minutes with an experienced student. I dream of one day having a 1.124" reamer and 1-7/64" drill bit to do bearing bores. We could go to 1.125", a regular size, but then we'd probably have to locktite it. |
1678 used to use a 1-1/8th wood cutting spade bit that I hand ground down a little on up to 0.125 aluminum plate using our old tiny drill press(still use it for rapidly iterating prototypes) >_> then we upgraded to a step drill. Man, that was only 4 years ago... Some days I really do miss the shipping crate "machine shop".
And no, I did not search "bearing block" in google images. |
