Bearings vs Bearing Blocks
Is there an advantage to using bearing blocks instead of just imbedding bearings into the frame of a chassis? If so, what is said advantage?
Historically, our team has just drilled 1.125" diameter holes into the sidewall of our chassis, and then popped the bearings in, and we were done! Worked well, was light, and easy to use. Just had to make sure the holes were in the right place when drilled, but never seemed to be too big of an issue (even for a team with no machining equipment beyond a drill press and a band saw).
I notice a lot of teams with WCD use bearing blocks, and VexPro sells giant blocks to hold bearings -- what's the point? I'm sure there's some big problem that they solve or nobody would use them, so I'm curious.
The Hitchhikers Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
