Go to Post 1) Field reset will want to do mean things to you. They have to remove the tubes. - EricH [more]
Unread 09-02-2015, 12:00 PM
mrwright's Avatar
mrwright mrwright is offline
Coach
AKA: Michael Wright
FRC #4522 (Team SCREAM)
Team Role: Coach
Rookie Year: 2013
mrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to behold
Bevel/Miter Gear Mounting Distances
So we are playing around with bevel and miter gears for our gearboxes. We can't seem to find an easy to understand formula for determining the proper mounting distances.
Right now we are using the 15t bevel gear from VEX Pro and are trying to design a simple 90 degree 1:1 mesh.
Are there any handy formulas that you all use to determine the mounting distances?
We are familiar with spur gear mounting distances, mating proper DP, etc.
Can anyone help or give examples?
Unread 09-02-2015, 01:06 PM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Bevel/Miter Gear Mounting Distances
The mounting distance is usually listed with the product for miter gears. In the case of the Vex ones, this is 1.250". You can find it in the drawing here: http://content.vexrobotics.com/vexpr...g-20140211.PDF
<Now accepting CAD requests and commissions>
Unread 09-02-2015, 01:26 PM
mrwright's Avatar
Coach
AKA: Michael Wright
Team Role: Coach
Rookie Year: 2013
Ok. I see the drawing file and the distances listed. I can see that the bevel gears are 12 DP gears so 15 teeth divided by 12 gives me 1.25 in. for the mounting distances.
Do the same rules for spur gear mounting distances apply to bevel and miter gears as well?
For example, if I wanted to use a bevel gear with a 15 tooth input and a 30 tooth output and they were both 12 DP gears would my mounting distance be:
15 / 12 = 1.25
30 /12 = 2.5
Mounting distance = 3.75
Is that correct?
Unread 09-02-2015, 03:11 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
15 / 12 = 1.25
30 /12 = 2.5
Is that correct?
No, each gear mounts the appropriate distance from the inside corner for the number of teeth it has. If you were to "unfold" the box, you would have the sum of these two distances (plus the fold itself) as the distance between the holes. The "pitch cone" of each gear should intersect the inside corner of the gearbox at the same point, and those two cones should share a line where they are tangent to each other.
Unread 09-02-2015, 11:52 PM
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
There is no way to determine the mounting distances for miter or bevel gears solely from the tooth information. The mounting distances are dependent on the shape and size of the gear's hub and should be specified in drawings or data tables with the gears. Many of these gears are made with standard hub sizes so if that information isn't available from the seller it might be available in the manufactures product catalogs.
Unread 09-02-2015, 11:58 PM
mrwright's Avatar
Coach
AKA: Michael Wright
Team Role: Coach
Rookie Year: 2013
That makes sense. I have seen gear sets with the distances marked on them. I just didn't know whether or not if there was a simple formula to use.
Unread 09-03-2015, 12:46 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
When designing these you will need to have the bearing flanges on the miter/bevel side to take the axial load into the structure. I would also recommend a thrust bearing, an Oilite bronze bearing is ideal for this application. The Bearing Flange is 1/16" thick, and the Oilite Bearings are normally 1/16" thick in this size range. So make sure to account for another 0.125" behind each gear.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 09-03-2015, 01:28 AM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
The Vex miter gears have a smaller hub behind the main hub that protrudes out 1/16". You can put a thrust bearing/washer on that to save space, and/or forgo putting the thrust loads on the ball bearing.
Unread 09-03-2015, 09:03 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
This depends on what you are designing. If you are designing a swerve drive, yes, you need a thrust bearing so that the gearbox can support the robot weight. On the other hand, if all you are doing is turning the motor sideways then driving another gear or sprocket, or are transferring torque from one direction to another (e.g. a lobster drive), there will not be a significant axial load.
Unread 09-03-2015, 10:27 AM
InFlight's Avatar
AKA: Jim
Rookie Year: 2012
Miter and Bevel Gears require fairly tight tolerances to avoid excessive gear tooth wear. These Gears mating at an angle do induce thrust loads.
Skipping the inclusion of a $1 bronze or brass thrust washer is fine if your design, machining, and assembly tolerances are close to perfect. However, repeatable perfect machining and assembly don't seem to be a common characteristic during a rushed build season.
The thrust washer both distributes the thrust loads, and also provide a less hard wear surface between the steel gear & steel bearing. This is simply good engineering practice for use of these gears, your welcome to use it or ignore it.
Unread 09-03-2015, 12:04 PM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I thought miter/bevel gears by nature exert large axial forces? In a swerve drive you can have a thrust bearing on the module and a separate one on the miter/bevel gears to take two different thrust loads.
Unread 09-03-2015, 12:09 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
There is a little bit of hand waving here, but for the typical FRC swerve that uses 12DP 15T bevels with some reduction after to the wheel (the rough size modules 118, 1717, 973, 1625, etc... have run ) it's okay to use the radial bearing (typical an FR6/FR8 here) to handle these axial loads. If doing this make sure the gear is necked down such as the Vex bevel so it's not rubbing the outer race.
Starting fresh, and not having a massive pile of anecdotal data for these exact bevels to reference, I'd design in better thrust management (or do the math for what thrust you bearing can take and compare that to the loads generated).
Unread 09-03-2015, 01:51 PM
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Starting fresh, and not having a massive pile of anecdotal data for these exact bevels to reference, I'd design in better thrust management (or do the match for what thrust you bearing can take and compare that to the loads generated).
A 1" diameter bevel gear driven at the same speed as a 2" wheel delivering 100lb of force to that wheel still only sees a 50 lb thrust load. Increasing wheel size or reduction after the bevel stage, or reducing final force output, reduces this thrust load. Since the radial bearings typically take several hundred pounds radially, sounds reasonable that the groove is deep enough (min. ~30 degree span) to support that small of a thrust load as well. Sounds like some of those swerves did rely on the radial bearing in this way.
Edit: did wheel to bevel diameter ratio backwards. Fixed by multiplying thrust loads by 4.
Unread 09-03-2015, 02:51 PM
AdamHeard's Avatar
Lead Mentor
AFAIK they all relied on the traditional radial bearing to handle these thrust loads.
  #15   Spotlight this post!
Unread 09-03-2015, 03:07 PM
InFlight's Avatar
AKA: Jim
Rookie Year: 2012
Just dug out Shigley & Mithell Machine Design Text
For the VEX Miter gears the average gear tooth diameter is 0.926 inches, or a radius of 0.463 inch. For Miter gears both Pitch angles are 45°
Axial Bearing Load = (Torque / radius avg) tan (45°) sin(45°)
= (Torque/0.463) (1) (.707)
CIM Motor Torque at maximum power is 172 oz* in
Axial Gear Force = 172 (Ounce*In) * (.707) / 0.463 in = 262 oz or 16.4 lbs.
Directly driven by a CIM Motor. If there are typical swerve speed reduction stages of 4:1 or so ahead of the miter gears, you can multiply this axial force by that ratio as well.
