Go to Post REAL WORLD = TOP PERFORMANCE... otherwise, get used to Ramen Noodles dinner or living in your childhood bedroom. - Michael Blake [more]
Unread 26-12-2001, 23:21
mehtank's Avatar
mehtank mehtank is offline
#0759 (SPORK)
mehtank is an unknown quantity at this point
Send a message via ICQ to mehtank Send a message via AIM to mehtank
a [slightly advanced] mathematical puzzle
to keep your brain un-dead over the holiday. actually, the more i think about it, the advanced-er it becomes...
the thought came to me with the talk of possible objects that's been going around: what happens if you overinflate an inflatable cube? it seems to be an interesting mathematical problem, so i'll phrase it [a bit] more rigorously.
what is the maximum volume of a region completely bounded by 6 smooth surfaces, subject to the following conditions:
~ each surface is of unit area, bounded by 4 continuous curves of unit length intersecting at right angles
~ two surfaces intersect completely along a common edge, and are orthogonal at every point along their intersection
~ three surfaces come together at a corner
i think those are the only conditions... basically you have a unit cube made of rubber walls, but where the edges and vertices maintain fixed relations. what shape will give it the maximum enclosed volume, and what is that volume?
