Re: A message from REV Robotics
But wait just a sec. 8mm hex doesn't seem to be very common. Were you planning on releasing any 8mm hubs because without them I'm afraid there's little purpose for an 8mm hex output shaft. The plastic gear kits look interesting but to be honest without being able to couple metal sprockets and gears to the motor it's pretty limiting. Shame it's not 0.375" hex because that's off the shelf already https://www.servocity.com/html/hex_b...ping_hubs.html http://www.andymark.com/product-p/am-2231a.htm |
The decision to go with 8mm hex was actually a long and complex one. I am happy to share our thinking.
We know that it won't be perfect for everyone, but we did our best to try and consider that the majority of existing teams re-use their parts every year, and we didn't want to force anyone into another closed system. For new teams we will have many adapters and hubs available (either for sale or download) to help make using any existing parts work. Our system will stand on it's own where we will have everything that a team will need but we also make it a priority to play nice with others Greg |
Anyway, a quick search indicates that 5/16" (0.3135" finished dimension) hex broaches are available from popular distributors MSC Direct and McMaster-Carr at about one-third the price of an 8mm (0.3154" finished dimension) hex broach. About $130 for 5/16" vs. about $400 for 8mm. What is the actual size of REV's 8mm hex shaft? Will 5/16" work? |
However, MMC is not the only source for hex shaft stock -- for example, FRC teams generally have a much easier time fitting hex shafts into broached holes if they buy their shaft stock from VEXPro. So again, what is the actual size of REV's 8mm hex shaft? |
By now you guys may have noticed that FIRST has changed the ruling on servo legality (allowing any COTS servo) so the REV Servo is now legal for use on FRC bots. From the blue box for R29 Quote:
So when choosing servos (including the REV one) just make sure you understand the power consumption involved. |
Hey Greg, When do you anticipate having the REV-41-1097 Servo back in stock? Asking here on CD so others see the response and don't eat up your time enquiring directly.
There has been a huge demand on these servos in the past two weeks and have wiped us out. We have more on order, but it won't be for a few weeks until they arrive. I will post an exact date when we know for sure, but I am trying for the end of the month, but it likely will be the first week in April.
