Cutting down motor power
I've encountered a problem with reducing the power on motor outputs when slowing the robot down for demos. The original lines of code are:
Lifter.lift1.set(Robot.oi.xBox.getRawAxis(1)); Lifter.lift2.set(-Robot.oi.xBox.getRawAxis(1)); which run the lift at full speed as expected. When I change it to: Lifter.lift1.set(Robot.oi.xBox.getRawAxis(1)/(5/3)); Lifter.lift2.set(-Robot.oi.xBox.getRawAxis(1)/(5/3)); the lift runs slightly slower, which makes sense. Now where it starts making less sense. When I change it again to: Lifter.lift1.set(Robot.oi.xBox.getRawAxis(1)*(0.6) ); Lifter.lift2.set(-Robot.oi.xBox.getRawAxis(1)*(0.6)); it runs slower than dividing by 5/3, which it shouldn't. The worst one is: Lifter.lift1.set(Robot.oi.xBox.getRawAxis(1)*(3/5)); Lifter.lift2.set(-Robot.oi.xBox.getRawAxis(1)*(3/5)); which causes the lift to stop responding to input altogether. Has anyone else encountered this, does anyone know why this happens, and is there a way to make dividing by 5/3, multiplying by 0.6, and multiplying by 3/5 all do the same thing? Thanks! |
