Go to Post Robot: Gyro, please reset yourself and verify proper operation. Gyro: ... WHY IS THE EVERYTHING SPINNING SO FAST? HELP! ... Robot: Are you working yet? How about now? - EricVanWyk [more]
Unread 09-20-2015, 05:37 PM
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need assistance uploading code to Github.
Hey,
I've been trying to upload my code to a github repo, so I can work on it from school. Despite getting some help from another team through CD, I am still confused how to do this. I can figure out how to upload my code to a .git file on my pc, but I have no idea how to upload that to the repo on the github website.
If any additional info is needed for you to help, please ask!
Thanks!
Unread 09-20-2015, 09:15 PM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Need assistance uploading code to Github.
https://git-scm.com/book/en/v1/Getting-Started
Start there
All opinions are my own.
Unread 09-22-2015, 01:10 AM
ShortCircuit908's Avatar
ShortCircuit908 ShortCircuit908 is offline
King of Hacky Fixes
AKA: Caleb Milligan
FRC #4450 (Olympia Robotics Federation)
Rookie Year: 2014
ShortCircuit908 is an unknown quantity at this point
Simple guide using Git bash:
  1. Navigate to your workspace using the 'cd' command
  2. Code:
    git init
    (Creates an empty repository)
  3. Code:
    git remote add origin <SSH clone URL>
    (Adds the remote repository as 'origin.' <SSH clone URL> is the URL given to you by GitHub, resembilng git@github.com:Username/RepositoryName.git
  4. Code:
    git add -A
    (Adds current files to the repository)
  5. Code:
    git commit -am 'Initial commit'
    (Creates a commit with added files)
  6. Code:
    git push origin master
    (Pushes local commits to the remote repository)
It is recommended that you have a decent .gitignore file in the root directory of your workspace, in order to keep unnecessary files out of the repository. A good example of a .gitignore file can be found here.
Unread 09-22-2015, 02:05 PM
AKA: Joel Gallant
Rookie Year: 2012
Please take the time to actually understand git before using it with other people. Don't just copy paste commands from guides online.
Unread 09-23-2015, 11:42 AM
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
I am currently reading your guide to learn how to properly use Git, thanks!
Sorry if it appears like I'm in a rush, this code does need to be uploaded fast. (Currently going to upload the code, and then work on properly learning git)
EDIT: Managed to post the code to our repo! I'm continuing to learn git as I go on, but at least I can work on robot code from anywhere now
Unread 09-24-2015, 09:02 PM
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
Rookie Year: 2014
SamcFuchs will become famous soon enoughSamcFuchs will become famous soon enough
In terms of .gitignore, you can pretty much just use the /dist/ file. You don't really need anything else.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 09-24-2015, 09:16 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We use:
Code:
/bin/
sysProps.xml
/build/
/dist/
Unread 09-27-2015, 06:04 PM
SamcFuchs's Avatar
Programmer
AKA: Sam Fuchs
Rookie Year: 2014
Originally Posted by Joe Ross View Post
We use:
Code:
/bin/
sysProps.xml
/build/
/dist/
Yeah, looking back, I didn't think that reply through. Here's a .gitignore that I like. It leaves pretty much only the src.
https://github.com/team236/2016-prac...ter/.gitignore
Unread 09-28-2015, 11:26 PM
King of Hacky Fixes
AKA: Caleb Milligan
Rookie Year: 2014
You shouldn't need to ignore .xml files. In fact, you shouldn't, especially if your project uses a framework such as Maven, which is based off xml files, or if your project uses an XML properties file.
