Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 20-09-2015, 22:34
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Installing Java/Switching from LV
We are attempting to switch to Java for the next season but encounter an error every time we use the installer. It says: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: Auth cancel
We are at a loss. we've tried it several times with different computers over Ethernet, wireless, USB, and both the kit dlink and another router. All produce the same result.
We are wondering if: 1. we could install it manually from another Linux machine and how. 2. if we need to remove anything LabView related from the Rio before deploying Java code. 3. can we bring the Rio back to the state it was in when we first received it?
Thanks for the help.
The log of one install attempt (relevant error is at the bottom):
Code:
16/Sep/2015 16:44:05,241- MainApp: Found JRE, checking hash
16/Sep/2015 16:44:05,977- MainApp: Computed hash is 082F08397B0D3F63844AB472B5111C8C, official hash is 082F08397B0D3F63844AB472B5111C8C
16/Sep/2015 16:44:06,069- UntarController: Starting decompress of file C:\Users\Josh\Desktop\tools\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz to C:\Users\Josh\Desktop\tools
16/Sep/2015 16:44:06,077- UntarController: Untarring ejdk1.8.0_06/bin/
16/Sep/2015 16:44:06,077- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.sh
16/Sep/2015 16:44:06,078- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.bat
16/Sep/2015 16:44:06,079- UntarController: Untarring ejdk1.8.0_06/bin/jrecreate.config.properties
16/Sep/2015 16:44:06,079- UntarController: Untarring ejdk1.8.0_06/doc/
16/Sep/2015 16:44:06,080- UntarController: Untarring ejdk1.8.0_06/lib/
16/Sep/2015 16:44:06,080- UntarController: Untarring ejdk1.8.0_06/lib/JRECreate.jar
16/Sep/2015 16:44:06,084- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/
16/Sep/2015 16:44:06,085- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/
16/Sep/2015 16:44:06,085- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/
16/Sep/2015 16:44:06,085- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/
16/Sep/2015 16:44:06,085- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklist
16/Sep/2015 16:44:06,086- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/US_export_policy.jar
16/Sep/2015 16:44:06,087- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.security
16/Sep/2015 16:44:06,088- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/java.policy
16/Sep/2015 16:44:06,088- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/local_policy.jar
16/Sep/2015 16:44:06,089- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/blacklisted.certs
16/Sep/2015 16:44:06,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/trusted.libraries
16/Sep/2015 16:44:06,090- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/security/cacerts
16/Sep/2015 16:44:06,091- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.bfc
16/Sep/2015 16:44:06,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.bfc
16/Sep/2015 16:44:06,092- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/meta-index
16/Sep/2015 16:44:06,093- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.bfc
16/Sep/2015 16:44:06,094- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/resources.jar
16/Sep/2015 16:44:06,117- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.properties.src
16/Sep/2015 16:44:06,121- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/classlist
16/Sep/2015 16:44:06,123- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/net.properties
16/Sep/2015 16:44:06,124- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management-agent.jar
16/Sep/2015 16:44:06,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr.jar
16/Sep/2015 16:44:06,131- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jvm.hprof.txt
16/Sep/2015 16:44:06,132- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/calendars.properties
16/Sep/2015 16:44:06,133- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/
16/Sep/2015 16:44:06,133- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/
16/Sep/2015 16:44:06,133- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
16/Sep/2015 16:44:06,135- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/cursors.properties
16/Sep/2015 16:44:06,136- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_LinkDrop32x32.gif
16/Sep/2015 16:44:06,136- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/invalid32x32.gif
16/Sep/2015 16:44:06,137- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
16/Sep/2015 16:44:06,138- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
16/Sep/2015 16:44:06,139- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_MoveDrop32x32.gif
16/Sep/2015 16:44:06,140- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/images/cursors/motif_CopyDrop32x32.gif
16/Sep/2015 16:44:06,141- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/charsets.jar
16/Sep/2015 16:44:06,170- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/
16/Sep/2015 16:44:06,171- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.password.template
16/Sep/2015 16:44:06,172- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/snmp.acl.template
16/Sep/2015 16:44:06,173- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/jmxremote.access
16/Sep/2015 16:44:06,174- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/management/management.properties
16/Sep/2015 16:44:06,175- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/
16/Sep/2015 16:44:06,175- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiBold.ttf
16/Sep/2015 16:44:06,177- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightItalic.ttf
16/Sep/2015 16:44:06,179- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightDemiItalic.ttf
16/Sep/2015 16:44:06,182- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterBold.ttf
16/Sep/2015 16:44:06,186- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansDemiBold.ttf
16/Sep/2015 16:44:06,194- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaBrightRegular.ttf
16/Sep/2015 16:44:06,200- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaSansRegular.ttf
16/Sep/2015 16:44:06,215- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/LucidaTypewriterRegular.ttf
16/Sep/2015 16:44:06,221- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fonts/fonts.dir
16/Sep/2015 16:44:06,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/content-types.properties
16/Sep/2015 16:44:06,222- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/rt.jar
16/Sep/2015 16:44:06,456- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jexec
16/Sep/2015 16:44:06,457- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.6.properties.src
16/Sep/2015 16:44:06,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/applet/
16/Sep/2015 16:44:06,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/
16/Sep/2015 16:44:06,458- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunec.jar
16/Sep/2015 16:44:06,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/cldrdata.jar
16/Sep/2015 16:44:06,487- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/meta-index
16/Sep/2015 16:44:06,488- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunjce_provider.jar
16/Sep/2015 16:44:06,491- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/localedata.jar
16/Sep/2015 16:44:06,501- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/zipfs.jar
16/Sep/2015 16:44:06,503- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/dnsns.jar
16/Sep/2015 16:44:06,504- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/nashorn.jar
16/Sep/2015 16:44:06,522- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/ext/sunpkcs11.jar
16/Sep/2015 16:44:06,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/
16/Sep/2015 16:44:06,525- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/profile.jfc
16/Sep/2015 16:44:06,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jfr/default.jfc
16/Sep/2015 16:44:06,526- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/
16/Sep/2015 16:44:06,527- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/LINEAR_RGB.pf
16/Sep/2015 16:44:06,527- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/CIEXYZ.pf
16/Sep/2015 16:44:06,529- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/GRAY.pf
16/Sep/2015 16:44:06,529- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/sRGB.pf
16/Sep/2015 16:44:06,530- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/cmm/PYCC.pf
16/Sep/2015 16:44:06,539- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/logging.properties
16/Sep/2015 16:44:06,539- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/tzdb.dat
16/Sep/2015 16:44:06,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/hijrah-config-umalqura.properties
16/Sep/2015 16:44:06,541- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.bfc
16/Sep/2015 16:44:06,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/
16/Sep/2015 16:44:06,542- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
16/Sep/2015 16:44:06,543- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
16/Sep/2015 16:44:06,545- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansOblique.ttf
16/Sep/2015 16:44:06,548- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
16/Sep/2015 16:44:06,552- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/oblique-fonts/fonts.dir
16/Sep/2015 16:44:06,553- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfontj2d.properties
16/Sep/2015 16:44:06,554- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.11.properties.src
16/Sep/2015 16:44:06,555- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/sound.properties
16/Sep/2015 16:44:06,556- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.properties.src
16/Sep/2015 16:44:06,557- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.Turbo.properties.src
16/Sep/2015 16:44:06,558- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.properties.src
16/Sep/2015 16:44:06,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/currency.data
16/Sep/2015 16:44:06,559- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jce.jar
16/Sep/2015 16:44:06,562- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/jsse.jar
16/Sep/2015 16:44:06,566- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.RedHat.5.bfc
16/Sep/2015 16:44:06,567- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/
16/Sep/2015 16:44:06,568- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdt_socket.so
16/Sep/2015 16:44:06,569- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2gss.so
16/Sep/2015 16:44:06,570- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libhprof.so
16/Sep/2015 16:44:06,572- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/
16/Sep/2015 16:44:06,572- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/Xusage.txt
16/Sep/2015 16:44:06,573- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjvm.so
16/Sep/2015 16:44:06,623- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/server/libjsig.so
16/Sep/2015 16:44:06,623- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pcsc.so
16/Sep/2015 16:44:06,624- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/
16/Sep/2015 16:44:06,624- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjsig.so
16/Sep/2015 16:44:06,625- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/libjvm.so
16/Sep/2015 16:44:06,657- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/client/Xusage.txt
16/Sep/2015 16:44:06,658- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libinstrument.so
16/Sep/2015 16:44:06,659- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnpt.so
16/Sep/2015 16:44:06,659- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libdcpr.so
16/Sep/2015 16:44:06,661- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/
16/Sep/2015 16:44:06,661- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/Xusage.txt
16/Sep/2015 16:44:06,662- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjvm.so
16/Sep/2015 16:44:06,679- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/minimal/libjsig.so
16/Sep/2015 16:44:06,679- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsplashscreen.so
16/Sep/2015 16:44:06,682- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnet.so
16/Sep/2015 16:44:06,684- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsdt.so
16/Sep/2015 16:44:06,685- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsound.so
16/Sep/2015 16:44:06,685- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libnio.so
16/Sep/2015 16:44:06,687- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava_crw_demo.so
16/Sep/2015 16:44:06,688- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsoundalsa.so
16/Sep/2015 16:44:06,689- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjaas_unix.so
16/Sep/2015 16:44:06,690- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libkcms.so
16/Sep/2015 16:44:06,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/
16/Sep/2015 16:44:06,693- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jli/libjli.so
16/Sep/2015 16:44:06,694- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmanagement.so
16/Sep/2015 16:44:06,695- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libt2k.so
16/Sep/2015 16:44:06,699- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjawt.so
16/Sep/2015 16:44:06,700- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsunec.so
16/Sep/2015 16:44:06,703- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/jvm.cfg
16/Sep/2015 16:44:06,704- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjdwp.so
16/Sep/2015 16:44:06,707- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libunpack.so
16/Sep/2015 16:44:06,710- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/liblcms.so
16/Sep/2015 16:44:06,714- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt_headless.so
16/Sep/2015 16:44:06,715- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libfontmanager.so
16/Sep/2015 16:44:06,720- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjpeg.so
16/Sep/2015 16:44:06,723- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libzip.so
16/Sep/2015 16:44:06,725- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libawt.so
16/Sep/2015 16:44:06,731- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjsig.so
16/Sep/2015 16:44:06,733- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libmlib_image.so
16/Sep/2015 16:44:06,741- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libverify.so
16/Sep/2015 16:44:06,742- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjfr.so
16/Sep/2015 16:44:06,743- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libsctp.so
16/Sep/2015 16:44:06,744- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libj2pkcs11.so
16/Sep/2015 16:44:06,745- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/arm/libjava.so
16/Sep/2015 16:44:06,746- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/psfont.properties.ja
16/Sep/2015 16:44:06,747- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/fontconfig.SuSE.10.bfc
16/Sep/2015 16:44:06,747- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/lib/flavormap.properties
16/Sep/2015 16:44:06,748- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME.txt
16/Sep/2015 16:44:06,751- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/
16/Sep/2015 16:44:06,751- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/orbd
16/Sep/2015 16:44:06,752- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/keytool
16/Sep/2015 16:44:06,753- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmid
16/Sep/2015 16:44:06,753- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/rmiregistry
16/Sep/2015 16:44:06,754- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/pack200
16/Sep/2015 16:44:06,755- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/policytool
16/Sep/2015 16:44:06,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/servertool
16/Sep/2015 16:44:06,756- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/jjs
16/Sep/2015 16:44:06,757- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/tnameserv
16/Sep/2015 16:44:06,758- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/java
16/Sep/2015 16:44:06,759- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/bin/unpack200
16/Sep/2015 16:44:06,761- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/COPYRIGHT
16/Sep/2015 16:44:06,762- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/release
16/Sep/2015 16:44:06,763- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
16/Sep/2015 16:44:06,765- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/jre/README
16/Sep/2015 16:44:06,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/
16/Sep/2015 16:44:06,766- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/
16/Sep/2015 16:44:06,767- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jsse.jar
16/Sep/2015 16:44:06,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/
16/Sep/2015 16:44:06,771- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.access
16/Sep/2015 16:44:06,774- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/management.properties
16/Sep/2015 16:44:06,775- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/snmp.acl.template
16/Sep/2015 16:44:06,776- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management/jmxremote.password.template
16/Sep/2015 16:44:06,777- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/classlist
16/Sep/2015 16:44:06,779- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/
16/Sep/2015 16:44:06,779- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/localedata.jar
16/Sep/2015 16:44:06,798- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunjce_provider.jar
16/Sep/2015 16:44:06,802- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/meta-index
16/Sep/2015 16:44:06,803- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunpkcs11.jar
16/Sep/2015 16:44:06,807- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/ext/sunec.jar
16/Sep/2015 16:44:06,808- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/currency.data
16/Sep/2015 16:44:06,809- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/meta-index
16/Sep/2015 16:44:06,810- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/hijrah-config-umalqura.properties
16/Sep/2015 16:44:06,811- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jce.jar
16/Sep/2015 16:44:06,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/
16/Sep/2015 16:44:06,813- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsctp.so
16/Sep/2015 16:44:06,814- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pcsc.so
16/Sep/2015 16:44:06,815- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava.so
16/Sep/2015 16:44:06,818- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsig.so
16/Sep/2015 16:44:06,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/
16/Sep/2015 16:44:06,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjsig.so
16/Sep/2015 16:44:06,819- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/libjvm.so
16/Sep/2015 16:44:06,855- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/client/Xusage.txt
16/Sep/2015 16:44:06,856- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libhprof.so
16/Sep/2015 16:44:06,857- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jvm.cfg
16/Sep/2015 16:44:06,858- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2gss.so
16/Sep/2015 16:44:06,859- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/
16/Sep/2015 16:44:06,859- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/Xusage.txt
16/Sep/2015 16:44:06,860- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjvm.so
16/Sep/2015 16:44:06,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/server/libjsig.so
16/Sep/2015 16:44:06,901- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libzip.so
16/Sep/2015 16:44:06,902- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libj2pkcs11.so
16/Sep/2015 16:44:06,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/
16/Sep/2015 16:44:06,903- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/jli/libjli.so
16/Sep/2015 16:44:06,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/
16/Sep/2015 16:44:06,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/Xusage.txt
16/Sep/2015 16:44:06,905- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjvm.so
16/Sep/2015 16:44:06,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/minimal/libjsig.so
16/Sep/2015 16:44:06,922- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjava_crw_demo.so
16/Sep/2015 16:44:06,923- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjsdt.so
16/Sep/2015 16:44:06,923- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libmanagement.so
16/Sep/2015 16:44:06,924- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnio.so
16/Sep/2015 16:44:06,925- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libjaas_unix.so
16/Sep/2015 16:44:06,925- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnpt.so
16/Sep/2015 16:44:06,926- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libsunec.so
16/Sep/2015 16:44:06,928- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libinstrument.so
16/Sep/2015 16:44:06,929- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libverify.so
16/Sep/2015 16:44:06,929- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/arm/libnet.so
16/Sep/2015 16:44:06,930- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/tzdb.dat
16/Sep/2015 16:44:06,931- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/content-types.properties
16/Sep/2015 16:44:06,932- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/rt.jar
16/Sep/2015 16:44:07,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/management-agent.jar
16/Sep/2015 16:44:07,043- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/net.properties
16/Sep/2015 16:44:07,044- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/logging.properties
16/Sep/2015 16:44:07,044- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/jvm.hprof.txt
16/Sep/2015 16:44:07,045- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/
16/Sep/2015 16:44:07,045- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/US_export_policy.jar
16/Sep/2015 16:44:07,046- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.policy
16/Sep/2015 16:44:07,046- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/trusted.libraries
16/Sep/2015 16:44:07,047- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/cacerts
16/Sep/2015 16:44:07,048- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/blacklist
16/Sep/2015 16:44:07,048- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/java.security
16/Sep/2015 16:44:07,049- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/security/local_policy.jar
16/Sep/2015 16:44:07,049- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/calendars.properties
16/Sep/2015 16:44:07,050- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/lib/resources.jar
16/Sep/2015 16:44:07,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/
16/Sep/2015 16:44:07,054- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/java
16/Sep/2015 16:44:07,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/keytool
16/Sep/2015 16:44:07,055- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmiregistry
16/Sep/2015 16:44:07,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/bin/rmid
16/Sep/2015 16:44:07,056- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact3/release
16/Sep/2015 16:44:07,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/
16/Sep/2015 16:44:07,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/
16/Sep/2015 16:44:07,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/
16/Sep/2015 16:44:07,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/
16/Sep/2015 16:44:07,057- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/arm/libj2pkcs11.so
16/Sep/2015 16:44:07,058- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/
16/Sep/2015 16:44:07,058- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunpkcs11/lib/ext/sunpkcs11.jar
16/Sep/2015 16:44:07,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/
16/Sep/2015 16:44:07,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/
16/Sep/2015 16:44:07,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/
16/Sep/2015 16:44:07,061- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/nashorn/lib/ext/nashorn.jar
16/Sep/2015 16:44:07,079- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/
16/Sep/2015 16:44:07,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/
16/Sep/2015 16:44:07,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/
16/Sep/2015 16:44:07,080- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/locales/lib/ext/localedata.jar
16/Sep/2015 16:44:07,096- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/
16/Sep/2015 16:44:07,096- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/
16/Sep/2015 16:44:07,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/
16/Sep/2015 16:44:07,097- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/arm/libsunec.so
16/Sep/2015 16:44:07,099- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/
16/Sep/2015 16:44:07,100- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/sunec/lib/ext/sunec.jar
16/Sep/2015 16:44:07,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/
16/Sep/2015 16:44:07,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/
16/Sep/2015 16:44:07,101- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/
16/Sep/2015 16:44:07,102- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libdt_socket.so
16/Sep/2015 16:44:07,102- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjdwp.so
16/Sep/2015 16:44:07,104- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libjava_crw_demo.so
16/Sep/2015 16:44:07,105- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libnpt.so
16/Sep/2015 16:44:07,106- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/arm/libhprof.so
16/Sep/2015 16:44:07,107- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/debug/lib/jvm.hprof.txt
16/Sep/2015 16:44:07,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/
16/Sep/2015 16:44:07,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/
16/Sep/2015 16:44:07,108- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/gcf/lib/gcf.jar
16/Sep/2015 16:44:07,109- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/
16/Sep/2015 16:44:07,110- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/
16/Sep/2015 16:44:07,110- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/options/charsets/lib/charsets.jar
16/Sep/2015 16:44:07,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/
16/Sep/2015 16:44:07,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/
16/Sep/2015 16:44:07,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/
16/Sep/2015 16:44:07,126- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjsig.so
16/Sep/2015 16:44:07,127- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libjava.so
16/Sep/2015 16:44:07,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/
16/Sep/2015 16:44:07,128- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jli/libjli.so
16/Sep/2015 16:44:07,129- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libzip.so
16/Sep/2015 16:44:07,131- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/jvm.cfg
16/Sep/2015 16:44:07,132- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libsunec.so
16/Sep/2015 16:44:07,135- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/
16/Sep/2015 16:44:07,135- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/Xusage.txt
16/Sep/2015 16:44:07,135- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjvm.so
16/Sep/2015 16:44:07,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/minimal/libjsig.so
16/Sep/2015 16:44:07,153- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libverify.so
16/Sep/2015 16:44:07,154- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/
16/Sep/2015 16:44:07,154- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjvm.so
16/Sep/2015 16:44:07,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/libjsig.so
16/Sep/2015 16:44:07,197- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/server/Xusage.txt
16/Sep/2015 16:44:07,198- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libj2pkcs11.so
16/Sep/2015 16:44:07,198- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnio.so
16/Sep/2015 16:44:07,199- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/libnet.so
16/Sep/2015 16:44:07,201- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/
16/Sep/2015 16:44:07,201- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjvm.so
16/Sep/2015 16:44:07,232- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/libjsig.so
16/Sep/2015 16:44:07,233- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/arm/client/Xusage.txt
16/Sep/2015 16:44:07,234- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/rt.jar
16/Sep/2015 16:44:07,320- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/meta-index
16/Sep/2015 16:44:07,320- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/
16/Sep/2015 16:44:07,320- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/cacerts
16/Sep/2015 16:44:07,321- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/US_export_policy.jar
16/Sep/2015 16:44:07,322- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.security
16/Sep/2015 16:44:07,322- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/blacklist
16/Sep/2015 16:44:07,323- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/local_policy.jar
16/Sep/2015 16:44:07,323- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/trusted.libraries
16/Sep/2015 16:44:07,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/security/java.policy
16/Sep/2015 16:44:07,324- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jce.jar
16/Sep/2015 16:44:07,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/logging.properties
16/Sep/2015 16:44:07,326- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/resources.jar
16/Sep/2015 16:44:07,333- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/hijrah-config-umalqura.properties
16/Sep/2015 16:44:07,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/
16/Sep/2015 16:44:07,334- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/localedata.jar
16/Sep/2015 16:44:07,346- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/meta-index
16/Sep/2015 16:44:07,347- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunpkcs11.jar
16/Sep/2015 16:44:07,351- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunec.jar
16/Sep/2015 16:44:07,352- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/ext/sunjce_provider.jar
16/Sep/2015 16:44:07,355- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/currency.data
16/Sep/2015 16:44:07,355- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/calendars.properties
16/Sep/2015 16:44:07,356- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/classlist
16/Sep/2015 16:44:07,357- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/tzdb.dat
16/Sep/2015 16:44:07,358- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/net.properties
16/Sep/2015 16:44:07,359- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/jsse.jar
16/Sep/2015 16:44:07,363- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/lib/content-types.properties
16/Sep/2015 16:44:07,364- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/release
16/Sep/2015 16:44:07,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/
16/Sep/2015 16:44:07,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmiregistry
16/Sep/2015 16:44:07,365- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/rmid
16/Sep/2015 16:44:07,366- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/keytool
16/Sep/2015 16:44:07,367- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact2/bin/java
16/Sep/2015 16:44:07,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/
16/Sep/2015 16:44:07,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/release
16/Sep/2015 16:44:07,368- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/
16/Sep/2015 16:44:07,369- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/classlist
16/Sep/2015 16:44:07,370- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/rt.jar
16/Sep/2015 16:44:07,426- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/tzdb.dat
16/Sep/2015 16:44:07,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/net.properties
16/Sep/2015 16:44:07,427- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/calendars.properties
16/Sep/2015 16:44:07,428- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/hijrah-config-umalqura.properties
16/Sep/2015 16:44:07,428- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/currency.data
16/Sep/2015 16:44:07,429- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jsse.jar
16/Sep/2015 16:44:07,432- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/meta-index
16/Sep/2015 16:44:07,433- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/content-types.properties
16/Sep/2015 16:44:07,434- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/
16/Sep/2015 16:44:07,434- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/US_export_policy.jar
16/Sep/2015 16:44:07,435- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/cacerts
16/Sep/2015 16:44:07,436- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.security
16/Sep/2015 16:44:07,437- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/local_policy.jar
16/Sep/2015 16:44:07,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/java.policy
16/Sep/2015 16:44:07,438- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/trusted.libraries
16/Sep/2015 16:44:07,439- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/security/blacklist
16/Sep/2015 16:44:07,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/
16/Sep/2015 16:44:07,440- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunpkcs11.jar
16/Sep/2015 16:44:07,444- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/meta-index
16/Sep/2015 16:44:07,444- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunec.jar
16/Sep/2015 16:44:07,446- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/localedata.jar
16/Sep/2015 16:44:07,459- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/ext/sunjce_provider.jar
16/Sep/2015 16:44:07,463- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/jce.jar
16/Sep/2015 16:44:07,466- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/resources.jar
16/Sep/2015 16:44:07,470- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/logging.properties
16/Sep/2015 16:44:07,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/
16/Sep/2015 16:44:07,471- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libverify.so
16/Sep/2015 16:44:07,472- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/
16/Sep/2015 16:44:07,472- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jli/libjli.so
16/Sep/2015 16:44:07,474- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libzip.so
16/Sep/2015 16:44:07,475- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/
16/Sep/2015 16:44:07,475- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjvm.so
16/Sep/2015 16:44:07,493- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/libjsig.so
16/Sep/2015 16:44:07,493- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/minimal/Xusage.txt
16/Sep/2015 16:44:07,497- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnet.so
16/Sep/2015 16:44:07,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/jvm.cfg
16/Sep/2015 16:44:07,499- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libnio.so
16/Sep/2015 16:44:07,500- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libj2pkcs11.so
16/Sep/2015 16:44:07,501- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjava.so
16/Sep/2015 16:44:07,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/
16/Sep/2015 16:44:07,502- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjsig.so
16/Sep/2015 16:44:07,503- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/Xusage.txt
16/Sep/2015 16:44:07,503- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/server/libjvm.so
16/Sep/2015 16:44:07,546- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libjsig.so
16/Sep/2015 16:44:07,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/
16/Sep/2015 16:44:07,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjsig.so
16/Sep/2015 16:44:07,547- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/Xusage.txt
16/Sep/2015 16:44:07,548- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/client/libjvm.so
16/Sep/2015 16:44:07,581- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/lib/arm/libsunec.so
16/Sep/2015 16:44:07,583- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/
16/Sep/2015 16:44:07,583- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/keytool
16/Sep/2015 16:44:07,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/compact1/bin/java
16/Sep/2015 16:44:07,584- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/
16/Sep/2015 16:44:07,585- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/
16/Sep/2015 16:44:07,585- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/
16/Sep/2015 16:44:07,585- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/
16/Sep/2015 16:44:07,585- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/
16/Sep/2015 16:44:07,585- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/controls/lib/ext/jfxrt-controls.jar
16/Sep/2015 16:44:07,605- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/
16/Sep/2015 16:44:07,605- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/
16/Sep/2015 16:44:07,605- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.platform.properties
16/Sep/2015 16:44:07,606- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/javafx.properties
16/Sep/2015 16:44:07,606- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/
16/Sep/2015 16:44:07,606- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/liblens_porting.so
16/Sep/2015 16:44:07,607- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_iio.so
16/Sep/2015 16:44:07,610- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_sw.so
16/Sep/2015 16:44:07,611- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font_t2k.so
16/Sep/2015 16:44:07,617- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_eglfb.so
16/Sep/2015 16:44:07,620- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass.so
16/Sep/2015 16:44:07,621- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libjavafx_font.so
16/Sep/2015 16:44:07,622- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_es2_eglfb.so
16/Sep/2015 16:44:07,623- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libprism_common.so
16/Sep/2015 16:44:07,624- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/arm/libglass_lens_dfb.so
16/Sep/2015 16:44:07,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/
16/Sep/2015 16:44:07,628- UntarController: Untarring ejdk1.8.0_06/linux_arm_vfp_sflt/extensions/fx/graphics/lib/ext/jfxrt-graphics.jar
16/Sep/2015 16:44:07,678- CreateJreController: Staring JRE Creation
16/Sep/2015 16:44:07,678- CreateJreController: Creator location: C:\Users\Josh\Desktop\tools\ejdk1.8.0_06\lib\JRECreate.jar
16/Sep/2015 16:44:07,678- CreateJreController: Command: [java, -jar, C:\Users\Josh\Desktop\tools\ejdk1.8.0_06\lib\JRECreate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
16/Sep/2015 16:44:07,986- CreateJreController: Successfully Created JRE!
16/Sep/2015 16:44:12,850- ConnectRoboRioController: Connecting to roborio-4080.local
16/Sep/2015 16:44:12,851- ConnectRoboRioController: Checking for mDNS connection to the roboRio
16/Sep/2015 16:44:25,291- ConnectRoboRioController: Found mDNS connection
16/Sep/2015 16:44:25,291- ConnectRoboRioController: Connected to the roboRio at roborio-4080.local
16/Sep/2015 16:44:25,311- DeployController: Removed the old tgz file
16/Sep/2015 16:44:25,311- DeployController: Starting zip
16/Sep/2015 16:44:25,315- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE, putting tar entry is JRE
16/Sep/2015 16:44:25,315- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bin, putting tar entry is JRE/bin
16/Sep/2015 16:44:25,316- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bin\java, putting tar entry is JRE/bin/java
16/Sep/2015 16:44:25,316- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
16/Sep/2015 16:44:25,317- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
16/Sep/2015 16:44:25,317- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
16/Sep/2015 16:44:25,318- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\bom, putting tar entry is JRE/bom
16/Sep/2015 16:44:25,319- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib, putting tar entry is JRE/lib
16/Sep/2015 16:44:25,319- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
16/Sep/2015 16:44:25,319- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
16/Sep/2015 16:44:25,320- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\client\libjsig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
16/Sep/2015 16:44:25,320- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\client\libjvm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
16/Sep/2015 16:44:25,497- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\client\Xusage.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
16/Sep/2015 16:44:25,497- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
16/Sep/2015 16:44:25,497- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\jli\libjli.so, putting tar entry is JRE/lib/arm/jli/libjli.so
16/Sep/2015 16:44:25,501- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
16/Sep/2015 16:44:25,501- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libdt_socket.so, putting tar entry is JRE/lib/arm/libdt_socket.so
16/Sep/2015 16:44:25,502- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libhprof.so, putting tar entry is JRE/lib/arm/libhprof.so
16/Sep/2015 16:44:25,507- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
16/Sep/2015 16:44:25,512- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libjava_crw_demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
16/Sep/2015 16:44:25,513- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
16/Sep/2015 16:44:25,521- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
16/Sep/2015 16:44:25,521- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
16/Sep/2015 16:44:25,524- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
16/Sep/2015 16:44:25,527- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
16/Sep/2015 16:44:25,528- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libverify.so, putting tar entry is JRE/lib/arm/libverify.so
16/Sep/2015 16:44:25,530- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
16/Sep/2015 16:44:25,533- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\calendars.properties, putting tar entry is JRE/lib/calendars.properties
16/Sep/2015 16:44:25,533- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
16/Sep/2015 16:44:25,536- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
16/Sep/2015 16:44:25,537- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
16/Sep/2015 16:44:25,537- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
16/Sep/2015 16:44:25,537- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
16/Sep/2015 16:44:25,538- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\ext\sunjce_provider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
16/Sep/2015 16:44:25,547- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
16/Sep/2015 16:44:25,548- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
16/Sep/2015 16:44:25,552- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
16/Sep/2015 16:44:25,563- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
16/Sep/2015 16:44:25,563- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\logging.properties, putting tar entry is JRE/lib/logging.properties
16/Sep/2015 16:44:25,564- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
16/Sep/2015 16:44:25,564- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
16/Sep/2015 16:44:25,564- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
16/Sep/2015 16:44:25,581- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
16/Sep/2015 16:44:25,992- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security, putting tar entry is JRE/lib/security
16/Sep/2015 16:44:25,992- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\blacklist, putting tar entry is JRE/lib/security/blacklist
16/Sep/2015 16:44:25,993- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\cacerts, putting tar entry is JRE/lib/security/cacerts
16/Sep/2015 16:44:25,996- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\java.policy, putting tar entry is JRE/lib/security/java.policy
16/Sep/2015 16:44:25,996- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\java.security, putting tar entry is JRE/lib/security/java.security
16/Sep/2015 16:44:25,997- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\local_policy.jar, putting tar entry is JRE/lib/security/local_policy.jar
16/Sep/2015 16:44:25,998- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\trusted.libraries, putting tar entry is JRE/lib/security/trusted.libraries
16/Sep/2015 16:44:25,998- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\security\US_export_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
16/Sep/2015 16:44:25,998- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
16/Sep/2015 16:44:26,002- DeployController: Processing file C:\Users\Josh\Desktop\tools\JRE\release, putting tar entry is JRE/release
16/Sep/2015 16:44:26,974- DeployController: Failure to send JRE to the roboRio
	at com.jcraft.jsch.Session.connect(Session.java:511) ~[java-installer.jar:?]
	at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
	at edu.wpi.first.wpilib.javainstaller.Controllers.DeployController.lambda$initialize$10(DeployController.java:85) [java-installer.jar:?]
	at edu.wpi.first.wpilib.javainstaller.Controllers.DeployController$$Lambda$174/1275153275.run(Unknown Source) [java-installer.jar:?]
	at java.lang.Thread.run(Unknown Source) [?:1.8.0_45]
16/Sep/2015 16:44:43,474- ErrorController: Exiting from error screen
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
