Go to Post There really is nothing else that needs to be said. - billbo911 [more]
Unread 22-09-2015, 20:38
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
Team Role: Mechanical
Rookie Year: 2014
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
am-0915a to Banebots 1/2 hex question
Hi,
Our team is looking on using our am-0915a gear motors directly mounted to intake wheels. The issue we're finding is that the 0915a outputs to a 10mm keyed shaft the the banebots wheels we're looking at accept a 1/2" hex input. Normally this wouldn't be an issue as there are plenty of 4mm, 8mm, and 12mm to 1/2" hex converters but I haven't found any 10mm adapters. Has anyone else faced this challenge with their intakes yet? Thanks
Unread 22-09-2015, 20:51
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: am-0915a to Banebots 1/2 hex question
If you're set on direct driving, I'd see if you can find a 1/2" keyed version of the wheel and use this adapter: http://www.andymark.com/product-p/am-0996.htm. Banebot discontinued them but I'm sure there's a few floating around on the internet.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 22-09-2015, 20:57
jkelleyrtp's Avatar
AKA: Jon Kelley
Rookie Year: 2014
We're planning on buying these banebots wheels but if anyone can find some banebots compatible with your solution, we'd opt for those instead.
Unread 22-09-2015, 21:06
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Hhm, someone may have a better solution but you could try this adapter from RobotShop:
http://www.robotshop.com/en/hex-hub-...5in-2wide.html
3/8 in. diameter comes to about 9.5 mm. If you have something able to press it on tightly you may be able to get the shaft in. Or if you can turn the size of the shaft down slightly, you'll be set. If you manage that you may need to shave down the key as well but you'll have to see.
Not ideal, but I think it is doable.
EDIT:
I think these are actually 3/4 in. Hex, not 1/2 Hex. See the section "Specification" lower down on the linked page.
Unread 22-09-2015, 21:10
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Would also have to re broach the keyway to 4mm as well
I would just buy the motor separately and then use a vp with a 1/2 hex.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
