Go to Post There's a fine line between insanity and healthy obsesion with FIRST ... and sometimes I wonder which one I'm on - srawls [more]
Unread 23-09-2015, 22:55
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Rookie Year: 2011
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
1/2" Hex Shaft Bevel Gears
I'm working on a go cart with a swerve drive in the offseason with a couple of friends. We aim to have this driving at 20 MPH by FIRST competition season. Unfortunately we can't find 1/2 Inch Hex Shaft Bevel Gears anywhere. If anyone knows of a good place to find these it would be a huge help.
Unread 23-09-2015, 23:01
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: 1/2" Hex Shaft Bevel Gears
Hex Shafting is relatively unique to FRC. You're much more likely to find keyed bevel gears in this size. Or, you can broach your own. Getting a good arbor press and broach is a great investment for an FRC team.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 23-09-2015, 23:07
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
You can try using a 1/2'' hex broach instead. It's not a bad investment, the broach will end up being useful later anyways.
Wow, that's pretty fast for FRC. You're not using CIMs, are you?
Unread 23-09-2015, 23:11
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Over the summer, I did an extensive search for bevel/miter gears with .5" hex bore, couldn't find anything. It's not an industry standard, so they really aren't in demand.
You can find bevel and miter gears at SDP-SI: http://www.sdp-si.com/eStore/CoverPg/Gears.htm
You can also get bevel/miter gears from McMaster: http://www.mcmaster.com/#bevel-gears/=z2kqn1
Vex pro has 15t miter gears with a 3/8 hex bore: http://www.vexrobotics.com/vexpro/mo.../217-3344.html
But as Joe said, you'd either need to used the keyed bore, or broach your own.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 23-09-2015, 23:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
You will probably need to broach your own. The only hex bore miter gear I know of is the Vex one. I would go with their 3/8" hex bore gears and have a reduction to the wheels to reduce the load on them.
SDP-SI sells 1/2" bore bevel gears, all you'd need to do is buy a hex broach and broach them. They also sell 12mm bore bevel gears (as does QTCgear), which you can bore out to 1/2" on a lathe relatively easily.
How much are you planning to spend on this? Swerve drives, even simple ones, are quite expensive.
<Now accepting CAD requests and commissions>
Unread 24-09-2015, 07:22
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Rookie Year: 2011
I'm prepared to spend 500-800 dollars on the swerve modules. I found a 1/2 Inch Hex Broach on McMaster. Any suggestions for a good bevel gear to broach?
Unread 24-09-2015, 09:28
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I had good results with these from boston gear.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 24-09-2015, 17:15
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
I would recommend going with gears from Martin Sprocket and Gear over those from Boston Gear. The Martin gears are case hardened and will wear better with heavy use. You can find their catalog here http://www.martinsprocket.com/docs/d....pdf?sfvrsn=14 and look up the part numbers at any number of suppliers to find the gears to buy.
Unread 25-09-2015, 00:23
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
You might want to see if it's possible to increase your budget. I've BOM'd a few swerve designs of mine, as well as looked at a few from teams like 1640 (who provide excellent resources in their swerve central), and I wasn't able to make the cost go under about $200 for each module. You'll also want to take into account manufacturing expenses, which can either be nearly free (tooling) or very expensive depending on how much outsourcing you're doing, and how much that'll cost you. Also, don't forget to budget for an extra module or two as things are likely to break ...
Unread 26-09-2015, 17:54
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
I'd worry that case hardened gears would be hard to broach, however. Some teams have used non-hardened gears and then hardened them themselves afterwards.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 28-09-2015, 15:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Assuming there are 4 modules!
This is a go-kart which presumably won't get into a pushing match. Seems perfect for a 3-pod design, and eliminates the need for a perfect frame/suspension setup.
Unread 28-09-2015, 15:50
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
...We aim to have this driving at 20 MPH by FIRST competition season....
I'd like to be the second person to say just how absurdly fast that is for an FRC robot. To be clear you're not converting incorrectly, 20 mph is 29 fps. I'm not aware of anyone that's tried gearing for 29 fps, but I doubt anyone has successfully. It'd take most FRC robots (assuming ~120lbs) far too long to accelerate to be practical. As I recall our team's 'Speed Racer' in 2008 was geared for a free speed of 19fps, which was hard enough to drive... and was on a robot that generally turned rather than stopped... and the robot weighed around 50 pounds with battery (so it could accelerate very quickly).
I suspect something geared for a free speed of more like 14-20 fps would be much more well-suited for a game with demands for a high top speed.
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 28-09-2015, 15:55
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You're assuming this is for an FRC robot.
Unfortunately for that assumption, it's for a go-kart.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
