Go to Post It's ok to be tired. That's what CD Mods are for. - Jessica Boucher [more]
Unread 26-09-2015, 14:34
BillMyers BillMyers is offline
FTC #9378 (Kalani Robotics)
Rookie Year: 2014
BillMyers is an unknown quantity at this point
FTC K9bot running problems
Please let me know if this is not the right place to post my problems. And, by the way, I'm not at all clear how I will know if I have been answered.
Getting started on FTC 2015-6 we built a K9bot and very carefully followed the instructions. It worked! Except the servos. The Telemetry data shows that the "arm" and "claw" values are being set but the servos themselves don't move. Any advice?
More recently the K9 has begun to fail to start up. The "Robot Controller" window contains the messages: (1) Unable to open Modern Robotics USB Servo Controller. (2) Unable to find USB Device with serial number ALOOYAX3.
We don't think we changed anything, but now the K9 doesn't work anymore.
Unread 26-09-2015, 16:32
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: FTC K9bot running problems
Normally, I think this might go in the FTC sub-forum, but this is fine.
I think the telemetry data is reporting the "get()" function from the servos, which happens to be exactly the value you set on the servos since they can't actually report back a number (only be sent a number). So telemetry will look normal regardless of whether the servos actually move.
Is your servo controller plugged in? Servos plugged in correctly? Does the servo controller still work / light up?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
