Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 09-27-2015, 12:48 PM
ScottRandallWay ScottRandallWay is offline
FRC #2543
ScottRandallWay is an unknown quantity at this point
How to access 2nd Pnuematic Control
Our robot features two pnuematic module controllers. We can access the ports on the first module properly (0-7). I am unclear how to access the solenoids hooked to the second unit. When you create a new Solenoid object one of the constructors takes a module number and a port. I assume I need to use this call and designate the proper module number. Am I on the right track? How do I figure out what the module number is?
Scott
Unread 09-27-2015, 01:53 PM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: How to access 2nd Pnuematic Control
Scott
Next module will be 1.
Unread 09-27-2015, 03:24 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The next module will be whatever address you assign in the roboRIO WebDash: http://wpilib.screenstepslive.com/s/...ribution-panel. A new address needs to be assigned so that it won't conflict with the existing PCM, as both have an address of 0 by default.
