[OCCRA]: Fuse Block Alternative and the Control Box
Dear OCCRA
Rule RB2 states "The control box has been pre-wired for your convenience. Again for 2015, the VEX “Cortex” controller will be used. The electrical control system must still be enclosed inside a single, clear plastic control box. Teams need to neatly lay out all of the electrical components and arrange key components so that their indicator lights are clearly visible to both inspectors and refs.)
You may not alter or remove the Cortex, fuse block, relays, speed controllers or fuses/circuit-breakers from the safety container(s)."
Does this prohibit the use of equivalent electrical components not supplied in the KoP? Specifically, Victor SP motor controllers (217-9090) and the Blue Sea Systems ST Blade Fuse Block (5026)?
