Go to Post 1/4" baltic birch plywood is most of our metal. - z_beeblebrox [more]
Unread 10-10-2015, 21:27
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: Mechanical
Rookie Year: 2013
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Gearbox Calculations
I've been using JVN calculator for a long time to calculate gearbox specs/performance. However, I would like to explore different methods to do this, and I guess I also would want to put effort into it rather than have something doing it for me. In addition I also heard that JVN might be somewhat inaccurate, so I would like to seek out something more reliable.
So is there a set of equations for proper gearbox calculations? Links will be fine.
Thanks
Unread 10-10-2015, 21:38
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: Gearbox Calculations
This is more accurate for multiple motors, and Paul goes through the calculators in the presentation in the description of the paper. However, the big factor that this and JVNs calculator ignores is the voltage drop on the battery. There is a calculator floating around somewhere on CD that has a battery simulator along with the drive calcualtor, but I don't remember who wrote it.
http://www.chiefdelphi.com/media/papers/3166
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 11-10-2015, 08:39
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
How much work are you willing to apply to get a more accurate Calculation? JVN calculator is really pretty good but does have a few assumptions and "fudge factors" you could try improving on, but it is a fair amount of work that still will not be perfect, and by some regards, less useful.
Unread 11-10-2015, 09:22
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Not to push my own stuff, but I've got a drivetrain simulator (http://www.chiefdelphi.com/media/papers/3038) that takes voltage drop into account.
It was based off of Ether's formulas (http://www.chiefdelphi.com/media/papers/2868) and uses Paul Copioli's motor combining formulas.
Unread 11-10-2015, 14:35
AKA: Daniel Koh
Rookie Year: 2013
I got external help about this, and I agree, JVN is accurate, although it seems like the only think about it is that it assumes constant voltage. So if I'm right, then it shouldn't really matter what I use because the difference is going to be pretty small.
That being said, I think I'm going to stick with JVN for now.
Unread 11-10-2015, 15:00
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
^ I have used Michael's calculator before to calculate the optimal gear ratio to go a certain distance (such as 17.6fps to go 2ft under optimal conditions). I highly recommend using it a few times for the design leaders of your team.
<Now accepting CAD requests and commissions>
