Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 13-10-2015, 11:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: pic: 2015/2016 Robot Radio Comparison
Different radio. POE wasn't an option on the DLINK. If they decide to allow POE as an option, they will change the rule. Since the radio has been problematic in the past, I expect they will only allow options that have been thoroughly tested.
If you don't know what you should hook up then you should read a data sheet
Unread 13-10-2015, 10:57
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Originally Posted by orangemoore View Post
R32 is what will prevent you from doing this. It says you must power the radio from the VRM.
Why would that rule prevent the use of POE injectors? You could easily power the injector from the VRM.
The rule that I see being a problem is R38. It says that regulated circuits < 5A should be wired with 22AWG wire. You can find 22 gauge ethernet cable, but it's not very common.
Unread 13-10-2015, 11:27
AlexanderTheOK AlexanderTheOK is offline
Guy
Rookie Year: 2012
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Sorry to crash the party, but does anyone have a link to an ethernet switch that is actually reasonably smaller than the original D-Link? Not much of a... net gain (badum tish) in real estate if the new system takes up... you know... MORE space.
Unread 13-10-2015, 11:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
R32 would have prevented using a POE injector to power the radio from something other than the VRM, but that was last year's rules, and last year's radio didn't support POE anyway.
I am confident that the 2016 robot rules will address Power Over Ethernet one way or the other, either to make it explicitly legal or to restrict it.
Unread 13-10-2015, 12:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Originally Posted by Alan Anderson View Post
This assumes that the 2016 rules permit a network switch between the radio and the roboRIO. I can imagine being required to have them connected directly with no intervening devices.
Why would this be an issue? Plug both the roboRIO and the switch directly into the radio.
Unread 13-10-2015, 12:46
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
It would save a wire if the roboRIO could go through the switch. Then you would only have to run 1 ethernet cable to the new radio, instead of 1 to the switch, and 1 to the roboRIO.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 13-10-2015, 13:10
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
Rookie Year: 2012
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Here are the POE injectors sold by the company that makes these AP:
http://www.open-mesh.com/products/po...or-for-om.html
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 13-10-2015, 22:30
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Team Role: Leadership
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Is it waterproof?
Unread 14-10-2015, 20:21
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
Did it come with a Pear?
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
