Go to Post FIRST is like riding a bike. At first it may seem hard and confusing, but after a few tries you get the hang of it and its smooth sailing from then on out. - Tom Bottiglieri [more]
Unread 14-10-2015, 20:10
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Where to buy dog shifting parts?
Does anyone now where I can buy shifting dogs (the part that locks onto the gear) other than from andymark?
Also, can anyone tell me if and how this axle could be machined (this is off of a WCP DS shifting gearbox):
I'm attempting to design a 2 speed gearbox for the first time, so any pointers would be appreciated.
Last edited by SerpentEagle : 14-10-2015 at 20:11. Reason: Sorry, didn't relize the pic was going to be so huge
Unread 14-10-2015, 20:13
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Re: Where to buy dog shifting parts?
You can grab that particular axle here:http://www.vexrobotics.com/vexpro/mo.../217-3635.html
(other components separate are available at the bottom of the DS Shifter page)
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 14-10-2015, 20:29
Team Role: CAD
Rookie Year: 2015
-Aren
Ah, didn't catch that on the site. Thanks.
Unread 14-10-2015, 20:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
You can buy the WCP dog and shifting rod from Vex.
And the shaft as well.
Just look at their dog shifter page here and you can scroll down to where they list all the parts, and all the shifting bits have links to buy them separately. Same for their ball shifter things.
EDIT: Aren beat me to it.
<Now accepting CAD requests and commissions>
Unread 14-10-2015, 20:20
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
You can also buy the PTO Kit and get everything needed for that setup. We are going to try turning some of our 3CIM SS gearboxes to shifters. On mobile so I can't link but you can find it on the DS page.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 14-10-2015, 20:33
Team Role: CAD
Rookie Year: 2015
Ah thanks for mentioning that. Looks like my problems are solved.
Unread 14-10-2015, 20:18
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
You would need both a mill and a lathe the machine a stepped hex shaft like that. Start with a piece of hex stock (make sure it's the proper alloy!) the largest size required, clamp it to a flat surface, and sequentially face mill each edge down to the smaller size. The mill would also be used to put the slot in the shaft. Following this, a lathe would be used to round down the other end, bore the pin hole, and put the snap ring groove in.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-10-2015, 20:31
Team Role: CAD
Rookie Year: 2015
Thanks for the breakdown. Have you tried this yourself?
Unread 14-10-2015, 20:44
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Yes, our team has made similar parts before. It's not something I would do simply for a drop-in replacement -- it's a time consuming process and not worth the couple of bucks it would save to us. However, having the ability to do this opens up a lot of options. In our case, it enabled us to use an alternate design which required a longer rounded segment than on the stock shaft.
