Go to Post They showed me a new item and said "we don't know how to list this on the inventory." I took one look, started laughing and said "In my world that is called a game piece, aka, a tote." - RoboMom [more]
Unread 10-16-2015, 11:51 PM
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
Autonomous Code Troubleshooting
An issue that I am currently having trouble with Autonomous is that it only performs the code once. For example if it hit enable, the code will run perfectly however once I Disable it and hit Enable again, the code will not run.
Here is the portion of code that is in question.
Code:
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
    	Camera.USBCamInit(); //runs USB Camera
    	Auto.move=true; //Sets a variable to be true in the Auto class
     * This function is called periodically during autonomous
    	Auto.trashCan(); //This is the autonomous task
Code:
package org.usfirst.frc.team3647.robot;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Timer;
public class Auto {
	//static boolean move= false;
	public static boolean move;
	public static void trashCan()
		if (move){
			TrashCanLifter.lifter.set(1);
			Timer.delay(7);
			TrashCanLifter.lifter.set(0);
			move=false;
The end goal that I want it to do is the run the autonomous portion every time I hit enable instead of the autonomous portion to only work the first time I hit Enable.
Thanks!
Unread 10-17-2015, 12:13 AM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Re: Autonomous Code Troubleshooting
The problem with your code right now is that your move variable is set to true in robotInit but nowhere else. Since robotInit is only called when the roboRio first boots up, your auto code will only run once.
The fix that requires the least changes would probably be to put Auto.move=true into autonomousInit instead of robotInit. However, this may not be the smartest way to go depending on what else your code is doing.
