Go to Post We are not the families of competiting robot teams, but we are a family of Gracious and Professionalism, because we know it better than anyone in the world. - wsansewjs [more]
Unread 18-10-2015, 21:04
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
Team Role: Mechanical
Rookie Year: 2013
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
How to build good bumpers
I figured in light of Frank recently confirming the return of bumpers, I would see what other teams have done in the past that has worked, and maybe what has not worked regarding good bumpers. For 2014, 1073 used hinges , some c-channel, and a few pins that we could swap out fairly quickly. The only problem was that the hinges weren't all that great, and IIRC, they were constantly loose.
Unread 18-10-2015, 21:10
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: How to build good bumpers
I know that either 1114 or 254 (I cant remember) uses a special low friction material to slide by opponents during pin-holds.
Unread 18-10-2015, 21:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I believe 254 uses sailcloth or something similar.
The biggest thing with bumpers is to get the fabric nice and tight. What some teams will do is to staple (or otherwise secure) one side of the fabric, then have several people stretch it over the noodles and hold it while someone staples the other side down.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-10-2015, 21:20
Chris is me's Avatar
AKA: Pinecone
Tape your noodles in place before you wrap the bumper. This helps a lot in the assembly process and especially helps prevent sagging noodles.
Staple one side, then stretch the fabric as tight as you can before stapling the other side. Any amount of sag in the bumper is bad.
Remember that your bumpers can (by 2014 and previous rules) weigh up to 20 pounds, and there's no reason you can't make your structure that you use to mount the bumpers as beefy as you would like.
Unread 18-10-2015, 21:35
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
For reference, our standard set of plywood bumpers mounted with wood tee nuts weigh somewhere around 12 lbs, so there is a lot of room to grow.
Unread 18-10-2015, 22:07
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
The Lunatecs have recently made reversible bumpers out of thick fabric and velcro. Basically the red and blue fabric is sewn together on one side and then again in the middle. The free ends are then stapled to the backboard. Volia, you add velcro and you have a single set of bumpers that can be used for both (or all 3) alliances.
2015 MAR District Champions
Unread 19-10-2015, 00:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Another trick used to get the bumpers tight is to compress them before stapling. Some teams report using a custom device they made, but we just used our three large (10"?) c-clamps and a table top, and do one edge at a time.
Securing bumpers them with angle brackets works well, as long as you have an inch or more of bumper above the top of your frame perimeter. Mount two bolts to each side of the chassis facing up (should be easy with the KoP chassis; just use the holes already there), drop the bumpers over the robot into place, and secure with a second nut on each bolt. (Wing nuts or power nut driver recommended). Rivet nuts mounted in the frame and (captive?) bolts passing through the bumper's brackets could probably also be used for this, but we haven't tried it.
Unread 19-10-2015, 09:07
AKA: Pinecone
By the 2014 rules (and specifically the Q&A), pre-compressing your bumper noodles as you assemble them isn't legal. I'll find the actual rule after work, but I remember this being shown / proposed in a CD thread in 2014 and a Q&A ruling came in declaring it illegal. Sorry for the vagueness.
Unread 19-10-2015, 10:04
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
From 2014:
Q302
Q.R21 C states that teams should use a pair of 2.5" pool noodles. Does that requirement refer to the pool noodle's size when on the robot, the pool noodles size when purchased, or both? Is compressing pool noodles legal?
A.1) Both. 2) No.
Please note that while previous answers like this may provide guidance on the general thinking towards a rule area, unless/until it's asked for this season, there is no official ruling that applies for this year. Which means you may or may not be flagged for it by an inspector if it's not crystal clear in the rules/q&a for this year.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 19-10-2015, 04:42
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
Rookie Year: 1998
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
This^
It's more work during the build, but it is so worth it at competitions.
You will need a heavy duty sewing machine to work with the sailcloth.
Unread 19-10-2015, 07:45
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Totally agree with reversible bumpers. Why have a quick change bumper when you can just flip the color around even faster.
https://www.youtube.com/watch?v=XYTiRxLw7oA
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 19-10-2015, 09:48
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
Team Role: Leadership
Rookie Year: 2014
natejo99 is on a distinguished road
Team 74 did the same thing in 2014. It was pretty convienient at competitions.
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 19-10-2015, 09:53
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
In my mind the reversible bumpers and bumper covers teams have produced in the past never looks as "polished" as separate well made bumper sets. The key to good looking bumpers? Pick quality materials (plywood, noodles, and fabric) and take your time.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 19-10-2015, 10:02
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Yes. Plywood. Get the good, sanded both sides stuff, not the sheathing grade that is rough. It's only a few dollars more.
In 2014, someone decided hardwood planks (oak or maple, I think) would be suitable. They ended up splitting along the grain in several places.
  #15   Spotlight this post!
Unread 19-10-2015, 10:30
Team Role: Coach
Rookie Year: 2010
Why used sanded material when the other material works just as well and you'll be covering it up? That's like using high polished material when you plan on painting it anyway. Price difference is small ($19.18 vs $26.58) but I just don't see the point, does smooth plywood hold staples better than rough plywood?
And I think the rules have specified plywood for as long as I've been making bumpers, so hardwood shouldn't even be considered anyway. Plywood will take an impact better due to the crossing grain structure over hardwood, the results of hardwood would be exactly what you stated.
Andrew Basse
