Using encoder with talon SRX
Hi
Does anyone have any sample Java code on how to use encoders with the SRX? Having trouble finding any on the web and not sure which classes to use. Thank you |
Re: Using encoder with talon SRX
Check out the Talon Software Reference Manual.
http://www.ctr-electronics.com/talon...ical_resources Some key sections.... Section 7.3 for selecting the sensor. Section 5.3 for getter functions. Section 12 for closed-looping using the internal PIDF loop inside Talon firmware. Section 13 for setting/changing the sensor position. |
Thank you very much for your quick reply. I did not see the coding manual. What I was hoping for was more context I've been through a lot of those manuals. We had problems using the CANTalon class last year, and we were not sure if it was really necessary to use some other class to get it to work. Is there anyone out there with actual code they can share using quadrature encoders?
Do you remember what was the problems from last season with CANTalon? You should also read up on the web-based config, which will allow you to see quadrature position and velocity, even if there is no deployed roboRIO code. |
I did not know there was a CTR coding manual. I've been reading it now for an hour or so. Thank you. I don't have specifics yet on the problems other than canTalon did not work with our CAN BUS. The challenge is trying to figure out how it works without examples. We have a qudratue encoder on our motor, and we are accessing it through the CAN, but it is not clear what classes to use. Are there any examples out there of just basic usage?
I think I understand the original posters point - I've struggled with this a bit as a mentor myself. I had found the coding manual last year but never got things working quite right for us. I'm a java developer by trade but robotics is only a hobby and I fear some of the background context that most presume is known in advance is a bit of a hole for me.
Things I didn't see: - There are encoder classes if I remember right in wpilib. However if we hook the encoder to the talon we don't use them at all right? - a lot of the built in PID type functionality can't be used if the encoders are hooked to the talon right? The PID classes all expect to get the encoder feedback directly. - I assume hooking the encoders to the talon directly reduces overhead on the roborio and certainly free's up ports. I'd love to see a post that covers the pro's con's of either scenario and how you might use the wpilib PID controllers when the encoders are hooked directly to the talon srx I'm going back to reading the talon programming manual again (its been most of a year) and this year we have the luxury of a bench bot we can more easily experiment with so hopefully I'll be in a better position. Last year encoders weren't critical but this year I'm really hoping we can do better in autonomous mode than last year. Other topics that would be interesting for me would be a ramp/brake tutorial for dummies. I have yet to search on that one so maybe it exists. The comment has been made that we accelerate too quickly and stop too quickly so I'm assuming that we need to learn about those. |
Code:
talon.changeControlMode(ControlMode.Position); //Change control mode of talon, default is PercentVbus (-1.0 to 1.0) talon.setFeedbackDevice(FeedbackDevice.QuadEncoder); //Set the feedback device that is hooked up to the talon talon.setPID(0.5, 0.001, 0.0); //Set the PID constants (p, i, d) talon.enableControl(); //Enable PID control on the talon Code:
talon.set(5000); //Tells the talon to go to 5000 encoder counts, using the preset PID parameters. Code:
talon.setVoltageRampRate(rampRate); //Sets the max voltage ramp on the talon //This affects both starting and stopping Code:
talon.changeControlMode(ControlMode.PercentVbus); //Change control mode of talon, default is PercentVbus (-1.0 to 1.0) talon.setPID(0.0, 0.0, 0.0); //Set the PID constants (p, i, d) talon.enableControl(); //Enable PID control on the talon |
Thanks - that appears to be helpful. On the position front we weren't using the quad encoder (we have them though) we were using a pot that we hooked directly to the roborio - It was painful trying to arrive at the correct parameters to prevent oscillation or error on the steady state. This year I bought an absolute position encoder - we only used position on the motor that was raising/lowering a lifting arm. I suspect your example will work well with the absolute encoder.
I'm taking this week to go back through the programming doc's - last year we had mechanum wheels and I hadn't figured out how to make use of the encoders properly with the robot drive in mechanum mode. I doubt we're going to use mechanum this year but I may still try to solve that so that we have it in our toolbox so to speak. My goal this week is to integrate a few things like an example autonomous mode that will take a tank or arcade drive, drive it forward 10 feet, pivot 90' right, Go forward 10 feet, and so forth - try to create an acurrate box pattern. I'll post back any specific questions I hit - usually when I am doing this sort of thing I'm bogged down at work and trying to figure it out with the team working 6 days a week. Doesn't give me much time to methodically work through things. This year I have my own RoboRio at home that I can work through things in peace and quiet so that I have a better understanding when working with the students. Once I get that working I'll have to figure out if we need to integrate a gyro into the equation. |
Ok - so I got my hardware setup. I have 2 talon srx's setup with 2 of the optical encoders from andymark. I created a test button and added the following to the execute on the command for the button. It starts and stops the motor but I'm not sure it is really doing what I want. Basically I'm working towards a command that will cause the robot to travel forward x inches to be used in autonomous mode. The code below is what I used...the position on the encoder doesn't seem to wind up anywhere close to where I expect it to be also I think I'd have better results if it was running slower or there was a load on the wheel. The output from the print statements is before the code for ease of following. Obviously I'm totally overlooking something so any guidance is appreciated.
Start of Execute -264 -264 Code:
System.out.println("Start of Execute");
RobotDrive drive = RobotMap.driveSystemdrive;
CANTalon talon = RobotMap.driveSystemCANTalon1;
int currentPosition = talon.getEncPosition();
System.out.println(currentPosition);
System.out.println(talon.getEncPosition());
finished = true;
#10
For a benchtop system it does need a load or brake on the wheel to provide some inertia, otherwise the mechanical system will overshoot. It has no reason to slow down or stop and will continue to coast until your system drives it back the other way.
A normal FRC robot will have 150 lbs/# of wheels on top of carpet to resist movement. |
#11
Thanks - I'm rigging up a breaking system with a bungie cord to put a load on it. I guess what confused me (correct me if I'm wrong) is that I have a get encoder position before and after the call to set position and it has the same value before and after - I'd expect a difference. However I'm guessing thats because its an async call instead of a synchronous call to set position - another words it returns immediately instead of after the move is complete.
Also I've noticed that the command is getting called a minimum of 3 times for one button push - is this due to button bounce? I assumed the framework would have handled that. I think compensating for that may help |
