Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 10-22-2015, 08:48 PM
Jefferyfan3a Jefferyfan3a is offline
FTC #9378
Jefferyfan3a is an unknown quantity at this point
FTC programming problem
I can't use the
import com.qualcomm.robotcore.eventloop.opmode.OpMode;
import com.qualcomm.robotcore.hardware.DcMotor;
import com.qualcomm.robotcore.hardware.Servo;
import com.qualcomm.robotcore.util.Range;
and Dcmotor under it.
could u guys help me?
T.Y.
~_~
Unread 10-22-2015, 10:04 PM
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: FTC programming problem
Im not on an FTC team nor a programmer on my frc team but the syntax on that looks weird try this
import com.qualcomm.robotCore.eventLoop.opMode;
import com.qualcomm.robotCore.hardware.dcMotor;
import com.qualcomm.robotCore.hardware.servo;
import com.qualcomm.robotCore.util.range;
You can also try
import com.qualcomm.robotCore.*;
or
import com.qualcomm,robotcore.*;
Unread 10-23-2015, 09:00 AM
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
You can also try
or
IMO, the OP's syntax looks right. I'm not an FTC programmer either, but what you posted is definitely incorrect. I looked at the Javadoc for the FTC code, and the OP is using correct names for the classes and packages.
My guess would be that the project was not set up correctly, and the FTC libraries are not linked to it.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
