Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 25-10-2015, 14:10
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
OnlineMetals now stocking 6061 1/16'' 2''x1'' tubing
I just noticed that OnlineMetals is now stocking 1/16''-wall 2''x1'' rectangular 6061 aluminum tubing. I know a lot of teams have had trouble finding a supplier for this in the past (usually you can only find it in 6063), so I figured I'd mention it.
https://www.onlinemetals.com/merchan... 268&top_cat=0
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 25-10-2015, 16:58
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
Team Role: Coach
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Re: OnlineMetals now stocking 6061 1/16'' 2''x1'' tubing
This is great
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 25-10-2015, 17:32
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
I believe Brendan Browne ordered a stick and said that it actually came with sharp corners as well, not radiused like the picture shows.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-10-2015, 18:37
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
This is great!
Unread 25-10-2015, 20:04
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
This is great if you only need a small amount.
Brendan did confirm sharp corners in this post.
If you are placing a large order I would still go thru Adam, much better prices. Info can be found here.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 25-10-2015, 21:56
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Ordered six 60 inch pieces. With cutting fees and ground shipping to my location the total was just under $100.
Richard Wallace
since 2003
Unread 28-10-2015, 12:44
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
If you sign up for their mailing list you get 15% off coupons on a regular basis (usually once every month). I get 20% off coupons occasionally too. If you make a lot of orders then you get 20% off on your next order iirc.
<Now accepting CAD requests and commissions>
Unread 31-10-2015, 17:12
Rookie Year: 1996
My order arrived yesterday in an eight inch diameter tube with plastic end caps. The tube could have held more. Next time I will order ten pieces.
Richard Wallace
since 2003
Unread 31-10-2015, 18:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I have placed one order with OnlineMetals so far, for our 2014 summer practice chassis. The order included both C-channel and angle (all aluminum). The C-channel and angle were shipped separately from different locations, and the experience of the two half orders was like night and day. The angle aluminum (far heavier package) came in a 3" inside diameter tube (from Dallas TX?), and it arrived at the house utterly intact. This tube went to our build space, as its inside diameter was perfect to hold a tennis ball for our summer game. The C-channel came in a 2" inside diameter tube from Orlando, FL (I still have this tube in my garage, so I'm sure of the location), and one end of the tube had been blown out in shipping. I haven't seen very much torn strapping tape, but more than half of what I've seen was on that shipment. The metal was all there (it was strapping-taped together), but there was no paperwork inside, as especially contrasted with some rather extensive batch-specific paperwork on the aluminum from Dallas.
Unread 31-10-2015, 22:34
Marcow Marcow is offline
AKA: Marcus
Rookie Year: 1900
Marcow is just really niceMarcow is just really niceMarcow is just really niceMarcow is just really nice
Forgive me if it has already been mentioned, but online metals also has various coupon codes floating around the internet. A quick google search will turn them up. Some are stackable. I believe they have a system where if you order over 100$ worth of materials, you get 10% off. I added another 10% off coupon I found somewhere online and the total order came out pretty cheap.
Unread 28-10-2015, 13:05
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Excited to start ordering. Definitely can not wait. Having trouble finding a place locally for the rectangular tubing.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 28-10-2015, 16:55
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We've used Online Metals last year and this year for materials and they're awesome. One thing I will recommend, check to see if they have a warehouse nearby! We have one near my place of work, and I can place an order in the morning and pick it up in the afternoon.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 28-10-2015, 17:01
Ken Zaballos's Avatar
Ken Zaballos Ken Zaballos is offline
FRC #1983 (Skunk Works Robotics)
Rookie Year: 2007
Ken Zaballos is on a distinguished road
On top of that, If you enter WILLCALL in the "Add a Promotional Code:" box, you will receive an additional 15% off your order.
Unread 28-10-2015, 17:03
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Online Metals is a great company, and fills their niche very nicely.
I'd highly recommend teams find a way to order from a local metal supplier and spend $2-3k to get a huge stockpile of metal. You should pay somewhere between $2-4/lb depending on some factors, and get a bunch more metal.
It's definitely a spot where paying up front leads to huge savings. From then on Online Metals is a nice bonus for filling things you missed ASAP.
  #15   Spotlight this post!
Unread 28-10-2015, 22:18
page2067's Avatar
page2067 page2067 is online now
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
So we have used Online metals and love them - very easy to order and reliably received next day.
Also as East Coast team had been looking for a 0.062"x 1"x2" option - we have used Vexpro Versaframe past two years - a great product (particularly if it is hard to locate holes...) but expensive and seemed we could go to 0.062" vs. 0.1" for our needs.
So we bought the 1x2x0.062 bundle of this through Adam which was roughly 2/3rds cost vs Online (after shipping) and roughly 1/2 of the versaframe - but required order of 32x5' pieces - more than we need - but teaming with other local team made this very viable and cheaper. roughly week for delivery (From CA to CT). Delivered today and looks great. I hold no stock in Adam's company.
We will remain loyal customers of Online for other shapes, and for their rapid turn time - particularly during build.
