Go to Post I like drifting, but I have to go WRC. Putting a car where it doesn't belong feels right, like combining together drill motors and power window motors and putting them on a big patch of carpet. - Billfred [more]
Unread 27-10-2015, 23:04
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
Rookie Year: 2010
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
3397 offseason build project
My team is in the process of building a holonomic drive train, we will be using 4 Single Reduction Clamping Gearboxes with 4" DuraOmni Wheels (am-3047). (I know this video shows an ftc bot but im just using it as an example). I've never seen a holonomic chassis like this: https://youtu.be/Z0lUTMBbu9A?t=8s , that uses this type of wheel: http://www.andymark.com/product-p/am-3047.htm , can this type of omni wheel be used on a holonomic drive?
2014 Gateway Robotics Challenge Winners with 1985 and 2481
FRC IS LIFE
Robolions 3397 pages
facebook- https://www.facebook.com/robolions3397
youtube- https://www.youtube.com/user/robolions3397
Instagram- @robolions_3397, https://instagram.com/robolions_3397/
Unread 27-10-2015, 23:06
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: 3397 offseason build project
Yup, an omni wheel is an omni wheel in this case. You can use the DuraOmni to make a drivetrain like that no problem.
<Now accepting CAD requests and commissions>
Unread 28-10-2015, 07:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Yes. On CD, search for Killough Drive to find out more. Off-CD, Killough is more commonly used to describe 3-wheel (Kiwi) drive.
If you want your drive to strafe just as well as drive "forward", use 45 degree angle mounts. If you anticipate driving "forward/reverse" much more often than going "sideways", you may want to change those angles to 30 degrees or so.
