Re: New Products for 2016: Speculation, Wants
I'd love to see an electronic pressure controller or electronic variable pneumatic regulator.
I think the only issues we've ever had with VersaPlanetaries have been related to misuse or improper assembly.
40A 2 wire slip rings.
Same. This spring GOFIRST built a number of small robots using them as drive gearboxes (15 gearboxes total), and the only issues we had were traced to overgreasing them and a poor mounting job to the frame.
Would love to see VersaWheels with the "W" tread pattern in a 3.25" size. Image of the tread pattern:
http://www.vexrobotics.com/media/cat...1/217-2903.jpg |
Same here - I think we had 16 on our 4 robots (2 tethered machines) last year and no problems of any kind.
-Aren |
I used to think that too. With a little research I found two types of encoders that are <$30. You can get CUI 10X-V encoders for ~$24 dollars on digikey. That is a quality incremental encoder but some time you need absolute value on things. While after doing a little research I discovered this ~$28 magnetic encoder, have not used it but it is on my list if the need for absolutel positioning arises.
#10
On the topic of replacements for banebots wheels. At Championships, AndyMark was demoing some prototypes for a new line of HiGrip wheels that had different tread materials. They don't match perfectly to banebots(smooth tread, solid core etc.) however they may be a good replacement in many situations without going out of stock quite as quickly.
#11
#13
Yes, but made by Vex and sold under the Versa name for 25% the price McMaster hast them for (ideally)!
#14
If they are the same wheels that they had at IRI, they are pretty neat. There are two new compounds, a "one match" and "one event" wheel. Unfortunately, I forgot the exact durometers. The "one match" wheel was very soft and grippy so I would imagine it would be great for non-drive uses.
#15
