Re: New Products for 2016: Speculation, Wants
While we're discussing hex shaft and the like, one product I really would like to see from FRC suppliers are clamping hubs. They're a very simple solution to most of the problems of positioning things on shafts, and allow you to use simple round shaft, to boot.
Disclaimer: Off the OP's original topic...
As Greg stated it is often not in the best interest for companies to keep an inventory year round. Quote:
TL;DR For a team, unused inventory is still good for future uses. For companies, unsold inventory is an added cost and potentially causes operational restrictions. |
We do try to stock up as best as possible, but are faced with budgetary limits that prevent us from having everything we want. Some items we simply have to risk build season wait times. It also doesn't help that some vendors don't restock certain items until the December/January time frame. Based on that, we often chose to stock up on inventory we know we can replenish if we need a higher than expected quantity. If we run out of hex items in the middle of build, we may be backed into a corner. If we run out of round shaft, we know we can order them from anywhere. Last edited by Lil' Lavery : 04-11-2015 at 23:33. |
Last year I started a reserve, or rainy day fund equivalent, for certain mechanical parts to include hex shaft, certain fasteners, etc. The items I withheld were not accounted for on any team "inventory". My reserve consisted of two 3' 1/2" hex shafts, a handful of 1/2" bearings, two boxes of common rivet sizes, and a variety of hubs. Definitely not enough to build an entire robot with, but a good amount of things to use in an emergency (weekend repairs, out of stock, etc). This is something you have to build up to, much like reserve funding that an organization may or may not have. I understand and agree with your points, but wanted to share how we have implemented mitigation strategies. |
We've chosen to stock up on motor controllers, thunder hex, bearings, and square tubing, since we know we will use all of those things. We will purchase gear boxes as soon as we know the game, and the rest when we work out the details, if anything is still available by then; otherwise, we will compromise or make it ourselves.
I have no beef with the suppliers over things running out. They all do a better job of serving their customers than almost any businesses I've ever worked with. The companies we purchase this stuff from love high school robotics, and they go way beyond to not only try to get us what we need, but to develop new and better products very quickly. FRC has gotten so much more advanced, so quickly, and I think it's awesome. That's why I'm excited to see the new stuff soon! |
West Coast Products has then in stock for 18" and backordered for 3'. I'm not sure what shipping would be like though.
I'd love a 3.25" Vex Traction Wheel with the adaptable widths. Would be super useful. http://www.vexrobotics.com/traction-wheels.html
Therobotspace.com has both 18" and 3' Thunderhex in stock. I just picked up some yesterday, plus some other VexPro parts.
But I don't see what the obsession with hex is all about. What's wrong with a nice round keyed shaft? |
#10
You don't have to deal with cutting keys, putting keys into the keyway, or worry about the key falling out. With hex you put it in the bearing and you're done.
#11
It wouldn't be a new product per say but I'd love to see vexpro start carrying the navx board. For canadian teams it's a lot cheap ordering from vex due to shipping and the currency exchange.
#12
Strength (massive stress risers) Ease of use...no keys to lose during installation. No struggling to get the key in/out of the keyway on either mating part. No need to cut keys. Torque transmission (which goes into strength) The list goes on and on. |
#13
1. Round shaft is available in any material that can be put on a lathe 2. Round shaft, depending on how it's machined, will hold tighter tolerances than hex shaft which can be unbelievably important in various real world applications 3. Machining internal features for round shaft is (depending on the tolerances required) easier, faster, more precise, and cheaper than for hex Round shaft is not "completely inferior in every way" to hex. Hex shaft is easier to use and commonly meets the needs of most FRC applications but when your're in the real world there are times when you may need something else. Last edited by jman4747 : 05-11-2015 at 22:12. |
#15
We're not in the real world. This discussion is clearly about FRC and there really can be no debate that for FRC hex is a superior product.
