Go to Post You're never too cool for a giant conga line around an arena. - Michelle 236 [more]
Unread 05-11-2015, 22:07
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: New Products for 2016: Speculation, Wants
Originally Posted by Cory View Post
We're not in the real world. This discussion is clearly about FRC and there really can be no debate that for FRC hex is a superior product.
Looks real to me.
I would argue that we are in the real world and that our application has parameters that support the common use of 7075 anodized hex shaft. I believe the best practice not to make a blanket statement about material usage and instead to state it's usefulness in terms of our application.
Saying round shaft is always inferior isn't true. Even in FRC there are times when we may be better served with round shaft. I would never tell my students to always use hex or round shaft or aluminum or steel. I train them to pick the best thing for that application. If we have sponsor that will buy half a robots worth of hardware from mcmaster and machine shop that doesn't have hex broaches then round shaft might be a better choice that time around.
Oh and...
4. round shaft couplings and collars are easier to produce (again depending on required tolerances/features)
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 05-11-2015, 23:12
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Originally Posted by jman4747 View Post
Looks real to me.
Oh and...
Your not really at at a real world job. Your in a HS competition where the best choice is clearly ThunderHex or Hex Shafting for most applications if not close to all.
While I agree on the blanket statement, the round shafting is clearly the 1%/minority here. Round shafting + key ways are a major pain and I can't think of a situation where in FRC I'd really want to use round. Most likely if we come to a situation where do we want to use Key'd shafting we'd probably redesign or re evaluate our design.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 05-11-2015, 23:47
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Why we need this:
A 3/8" hex bore bearing with a 0.875" OD
Unread 05-11-2015, 23:58
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Originally Posted by page2067 View Post
Why we need this:
Because when I'm using 3/8" hex shaft it's very convenient.
Also I forgot to mention: 3/8" hex versahubs and sprockets! Or a 3/8" hex to 1/2" sleeve if that's not possible.
<Now accepting CAD requests and commissions>
Unread 06-11-2015, 00:03
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
I'd take hex over round 99 out of 100 times for transmitting torque, but I don't agree with a blanket statement that says hex is always the way to go, especially considering budget. It's undeniably cheaper to drive a McMaster Carr Sure-Grip wheel with a round shaft than a hex shaft.
Putting a hex in a 1.25" hardened steel worm is impossible for most teams that don't have access to a wire edm. Using a keyed shaft would be a better solution, especially if there isn't room in the worm for a 3/8" hex.
If you have a set of two driven rollers or wheels with a pair of bearings in between, you're forced to use a hex bearing here. The inner race of the hex bearing is much weaker than the inner race of the round bearing and has a sloppy fit. I'm pretty sure 254 solved this problem in the past on their outer wheels by using 1/2" keyed shaft...
Unread 06-11-2015, 00:05
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
No, they used 7/16" hex at the wheels.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 05-11-2015, 22:06
Rookie Year: 2010
2. Round shaft depending on how it's machined will hold tighter tolerances than hex shaft which can be unbelievably important in various real world applications
In the "real world", could you also just clamp the shaft instead?
