Go to Post I believe youth is contagious. I want to catch as much as I can! - Al Skierkiewicz [more]
Unread 02-11-2015, 10:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
VexPro Colson + ThunderHex
It's that time of year again - pre-purchase of anticipated parts! We usually get risk-averse in this phase, and a question came up when discussion drive trains. We really really like the idea of the vex pro Colson wheels since they're now the cheapest wheel setup available all things considered.
However, We're interested in trying ThunderHex. I like the beefy bearing support, and I also like the thru-hole since that would make life exceptionally easy for a few things in a WCD setup (#10 thru-bolt that acts as encoder attachment).
I have had experiences with plastic hubs and a steel square shaft before - the plastic eventually fatigues and rounds out. Is this an issue with the ThunderHex + Colson combo? It wouldn't necessary mean I don't use either, but I'd like to know if using them in combination for a potentially torque-heavy game is a bad idea over the course of a competition.
Edit - also useful to know for things like conveyors & wheeled shooters, which may see spikes in torque due to jamming/etc.
Unread 02-11-2015, 11:43
Chris is me's Avatar
AKA: Pinecone
Re: VexPro Colson + ThunderHex
Haven't used ThunderHex directly, but one point in favor of this combination is that the VexPro Colson hex profile is a very tight fit on even regular VexPro hex shafting. I don't expect there to be many problems with backlash or wear since there will still be a large contact patch between the wheel hub and the hex profile.
If you're really concerned, just buy the ThunderHex bearings and turn the ends of the shaft down to slightly-round.
Unread 02-11-2015, 15:38
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
3476 switched over to thunderhex. I highly recommend it. We still have our inventory of 1/2" hex because its pretty easy to use a lathe to convert to thunderhex.
As for high torque, we have the colson+ thunderhex combo on our 2013 robot now and we will see how well it does when we compete with it in China. I will let you know how it goes but I am confident it will be fine.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 02-11-2015, 17:21
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
We used thunderhex with plastic versahubs and colsons on our drive train all season without issue. The hubs are still tight.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 07-11-2015, 05:04
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Does anyone know when Thunder Hex will be back in stock?
We would really like to get some for an off season project.
Edit: I went looking outside of the VEX website for the parts. Some is available.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 03-12-2015, 16:27
Head Mentor
Just a follow up. We had no issues with this combo. The wheels and shafts worked fine playing the 2013 game.
