Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 02-11-2015, 12:30
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Trouble getting servo to work
We have successfully programmed with the servos that came with the KOP, but recently purchased a different one for slightly more toruque.
We cant get them to work. Its a hitec HS-5485HB. Its digital, unlike the analog KOP servos, but the specs suggest they should program the same.
The servo powers up but wont respond to position requests by the code.
ideas ??
Unread 02-11-2015, 22:16
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Trouble getting servo to work
It would help us a lot if you could tell us whether you're programming an FTC or FRC robot, along with the programming language you're using and your current hardware setup.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 02-11-2015, 23:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I agree with whippet that more info on both HW and SW use is needed.
One thing that strikes me as I look at the specs for this servo is the high current draw (500mA no load at 6V, presumably much higher when there's a load, much less at stall). You may want to check the voltage supply to the servo while you're trying to drive it; you may be pulling that voltage below the 4.8V required for reliable operation.
Unread 03-11-2015, 18:56
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Just for reference the roboRio spec for the 6VDC power is rated at 2.2 Amp total.
Unread 03-11-2015, 22:18
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Again, note that the 500mA spec is for no-load operation. This is just to produce enough torque to overcome the internal friction. If there is a load resisting the servo's attempted travel, the current use for each servo could easily be several amps.
Unread 04-11-2015, 13:38
None #4859
I dont think we tried plugging into a different PWM port. It returns to zero even when disabled.
Unread 05-11-2015, 07:34
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Is the PWM wire plugged in with the correct orientation? When the roboRio is disabled, the servo should be getting no PWM signal to go to any position including zero.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 03-11-2015, 02:59
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
ideas ??
Where are you connecting the servo motor?
Unread 03-11-2015, 16:04
None #4859
We are in FRC using java.
The servo is plugged directly to a PWM port of the roborio. We are using the servo class.
I dont think its a current draw problem. When we are testing the servo and it first gets power, it repositions itself to 0 degrees. The toruqe and movement look fine. If you turn it it repositions back to 0. So it seems to function normally, we just cant control it with the rio like we can with other servos.
Unread 03-11-2015, 17:15
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
Rookie Year: 2012
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Does the servo stop trying to move when the robot is disabled? What about when it is plugged into an unused PWM port?
