Go to Post The driver must have a relationship with the robot, the driver should talk to the robot, speak soft encouraging words to it. Pet names are also a good idea. If the driver does not love the robot, how can the driver learn to trust the robot. - Gboehm [more]
Unread 28-12-2001, 11:47
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
my guess to what game will be
After thinking this through here is what i have come up with: There is one movable goal. This moveable goal will be 4 feet by 4 feet. Made of the plywood sheet. On each corner there will be a caster and in the middle of each side there will be a caster. Therefore equaling 8 casters as the BOM says. Protecting the plywood will be the steel. The BOM says they are 4 feet long and there are 4 so therefore they would fit all the way around the plywood base. In the middle of the base would be the 3 inch PVC connected to the platform with with the 4 x 3 adjustable ring. In some fasion all 16 of those PVC pipes will go around the base and form 4 different compartments. Each compartment will be for a certain team. I think it will be 2v2 or 1v1v1v1. Now for the playing field: it will probably be same rectangle as usual. I also think it will have a divider in the middle and some sort of obstacle as allways. Maybe there will be 4 compartments divided equally in which each robot will sit and the goal will be in the middle. The teams would have to fight over the goal will putting things in each compartment. Maybe blocks, I don't think there will be balls.
What do you think????????????????????????
None of you go contacting Dean either cause this is my own personal opinion ok?????????? .........And all I had for sources is the BOM!!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
"Rigging" the game vs playing the game strategically - what's the difference? ColleenShaver Rules/Strategy 13 15-01-2003 10:33
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Next year: Make the game understandable archiver 1999 23 23-06-2002 22:53
