Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 03-11-2015, 22:52
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
Rookie Year: 2010
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
Help with gear sizes
Does anyone know the sizes of the two gears I have circled in this picture: https://drive.google.com/file/d/0B-U...ew?usp=sharing ,and where I can order the two gears?
2014 Gateway Robotics Challenge Winners with 1985 and 2481
FRC IS LIFE
Robolions 3397 pages
facebook- https://www.facebook.com/robolions3397
youtube- https://www.youtube.com/user/robolions3397
Instagram- @robolions_3397, https://instagram.com/robolions_3397/
Unread 03-11-2015, 22:58
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
Rookie Year: 2013
zinthorne will become famous soon enough
Re: Help with gear sizes
http://www.wcproducts.net/217-4156
Not sure what the gear size is. But my closest guess is that it is the 84t gear they mention in the description of the product.
Unread 03-11-2015, 23:00
zuzoom101 zuzoom101 is offline
Box knives and Cams
FRC #1939 (KuhNigIts)
Team Role: Driver
Rookie Year: 2013
zuzoom101 will become famous soon enough
On the VexPro website, it states that there is a total of 84 tooth spacing. For my team, we had a 11 tooth pinion gear on the motor, and this corresponded with a a 72 tooth gear, which we also ordered from the VexPro website. These details and four different gear ratios should be on the VexPro website on the description for the clamping gearbox, and the gears should be on another page. Here is the link to the gears: http://www.vexrobotics.com/vexpro/mo...-hex-bore.html
Unread 03-11-2015, 23:03
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Rookie Year: 2011
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Where did you get this picture from? If I had to take a guess the big gear on the drive shaft looks like an 84 tooth hex gear, assuming that those are 4" omni's. Also I'm pretty sure that there are 12 teeth on that pinion gear. I would suggest VexPro for gears, you can also buy the omni's there if you want.
Unread 03-11-2015, 23:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
And 84t gear would be larger than 4" omni wheels. That is a 72 tooth gear mating with a 12 tooth gear.
Gear diameter = (teeth + 2)/pitch. Vex gears are 20 pitch, so an 84t gear has a diameter of (84+2)/20 = 86/20 = 4.3" diameter. A 72t gear by comparison is 74/20 = 3.7" diameter.
<Now accepting CAD requests and commissions>
Unread 03-11-2015, 23:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Here is the link to the clamping gearbox page.
It has a number of options for gears, but by counting teeth and checking material, you should be able to cut it down to specific parts.
Unread 03-11-2015, 23:46
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The total number of teeth needed on the two gears need to add up to 84. The 11 & 13 tooth pinions (smaller of the two gears) shown on linked site are a special case. They cut on 12 & 14 T diameters respectively. The big gear is either 70 or 72 based on commonly available cim pinion gears.
A 72 t gear on a 4" wheel is a risky proposition. Any trash picked up from the floor will jam the gears. Gears are trash magnets.
If you don't know what you should hook up then you should read a data sheet
