Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 05-11-2015, 14:44
themaanas themaanas is offline
FTC #10295
themaanas is an unknown quantity at this point
Question [FTC]: Phone drains voltage...
When we connected the phone to our robot, the voltage that we measured dropped from about 12 volts to about 5 volts. Has anyone else encountered this problem? If so, how do we fix it?
Unread 05-11-2015, 17:36
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Re: [FTC]: Phone drains voltage...
Where are you measuring voltage?
Unread 07-11-2015, 16:24
FTC #10295
We are measuring the voltage at one of the Power Distribution Module's outputs
while the phone is connected. When the phone is not connected, it shows about 12 volts, but when it is connected, it shows about 5 volts.
Unread 07-11-2015, 18:34
DavisDad's Avatar
MechE
Rookie Year: 2012
Maybe the power is disabled unless in init or run mode?
