| You can spoil my row any time. |
| Thread Tools |
Rating:
Display Modes |
Pneumatics off board recharge packs
We are looking to create an off robot pneumatics recharge pack for this season and have had a hard time finding some good examples to start with. Could CD folks post a few pics of pneumatics off robot recharge packs that they liked. Thanks!
Re: Pneumatics off board recharge packs
I think because most of us thought strapping a compressor and an air tank on the back of a human was a bad idea. That slight possibility of a 100PSI rupture causing injury was a primary factor.
You should be able to find that discussion. |
JJ, What exactly are you trying to accomplish with the project? When would this be used? |
Also, bear in mind that if you are using this pack--in whatever form--to charge your tanks before matches, the way the rules were for 2015, you won't be able to have an onboard compressor. I want to say someone even Q&A'd it.
(For practice is another story--but then you just have to consider safety and getting the air to the robot.) |
I'd also like to point out the 2015 R70:
I have no idea if we are going to use it this season, but it looks like a great project for a few kids to take on. |
Not particularly FRC legal, but if you wanted a recharge pack. Probably need to add a regulator. Are if you want to barbecue...
#10
Re: Pneumatics hand
We are looking to create an grabber pneumatics (hand for this season to school kids at near area to give them chance to play with it,.
any some good examples to start with. Thanks! |
#12
In a re design we may add slots to the wood frame on the compressor side for improved cooling. Not that we've had an issue, more of a can't hurt improvement. |
#13
You would not be able to use the pack pictured above for competition under either of these 2015 rules - no battery, no switch, and no air tanks can be off board. There may be some other nitnoids, but I stopped looking after these obvious ones.
#14
I am also very confused by the pictured recharge pack. Not only is it not legal (must be controlled and powered by robot), but having tanks onboard the pack makes no sense to me. I am going to assume that your goal is to fill the tanks on the robot and that you started with the tanks on the pack full before connecting it to the robot. The air stored on board the pack will spread equally through out the system and drop in overall pressure. Then you would have to leave it connected with the compressor running until not only the robot was full, but also the onboard tanks. I believe that it would take an equal amount of time as without tanks to fill the robot, therefore it is unnecessary to have the tanks.
#15
