Go to Post We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers. - ToddF [more]
Unread 09-11-2015, 22:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
"Wobbling gear" reduction?
Has anybody every heard of this type of gear transmission:
https://www.youtube.com/watch?v=Nhy4hXdYCfw
It uses a wobbling ring with pins on it and what appears to be cycloidal teeth on the gears. Does anybody have any efficiency calculations or even guesses? It seems like a neat way to get a large reduction in a thin space.
<Now accepting CAD requests and commissions>
Unread 09-11-2015, 22:52
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: "Wobbling gear" reduction?
What would this have over a harmonic drive?
Unread 09-11-2015, 22:57
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Harmonic drives, to my understanding, rely on mechanical warping to function properly, and seem very tricky to design. This relies on completely different mechanisms to work and seems far easier to design and manufacture. I would not be confident making a harmonic drive, but I could see myself making this on a 2-axis CNC, manual mill, and lathe.
Unread 09-11-2015, 23:01
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Well, it looks like it would be a lot easier to make for one. Might be more durable too.
Unread 09-11-2015, 23:03
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
There was a thread on here about Cycloidal Gearboxes. this is virtually the same thing, but with different geometry.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 09-11-2015, 23:06
Robotics Engineer
You do need a deformable gear in a harmonic drive, but they can be 3D printed.
(That channel actually has a lot of interesting gear trains, like this one.)
I would seriously balk at attempting to calculate the tooth profile of those non-wobbling gears.
Unread 09-11-2015, 23:25
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
For FRC use I balk at using 3D printing both due to the efficiency loss as well as low strength. I've seen that channel and I definitely has interesting stuff on it.
Calculating the tooth profile should just be plugging in an equation, and I can always just ask the owner of the channel for them.
I was thinking of cycloidal gearboxes, but this has the advantage of not being eccentric, and thus you only need one wobble plate to counterbalance itself.
