Go to Post P.S. No matter what happens a build season, you will always have memories. - Briansmithtown [more]
Unread 10-11-2015, 19:50
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Rookie Year: 2010
Vikingtech2054 is an unknown quantity at this point
[FTC]: Team 7837: Res-Q Practice Run
Full Run Attempt
Hey I wanted to share a quick video, FTC Team 7837 did a full run practice for this years game Res-q. The majority of the robot is functioning manually we are just working on our autonomous and a few automated controls during teleop.
In the video we are driving the robot during the autonomous, like I said we are still developing our auto code but the plan/route is the same.
Let me know what you think, thanks.
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 10-11-2015, 19:55
wgardner's Avatar
wgardner wgardner is online now
Team Role: Coach
Rookie Year: 2012
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
Re: [FTC]: Team 7837: Res-Q Practice Run
Looks great! Nice job!
I would suggest running with debris on the field as it may throw off your autonomous routes and also get in the way of your ramp entry, and you'll want to figure out how to deal with those issues sooner rather than later.
Thanks for sharing!
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 10-11-2015, 19:59
wgardner's Avatar
Team Role: Coach
Rookie Year: 2012
Also, I may have this wrong, but it looked like you released the middle zip-line trigger with the robot on the floor. That violates Rule GS13 and would result in no score for the middle zipliner. You have to be on the mountain above the 2 inch white tape to release the middle and high triggers. And you should add the 2 inch white tape on the bottom of your mountain while you're at it.
Great job, again!
Unread 10-11-2015, 20:21
Rookie Year: 2010
Great job, again!
We did realize that rule with the zip liner after we did the practice run. We also did run some with debris on the ground, we have a plow on the front of our robot that prevents the tracks from running up on the debris. Hopefully it won't be an issue. Thanks for your insight.
Unread 10-11-2015, 21:27
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Very Nice!
How are you locating the rescue beacon/climber shelter?
Where are you competing? We hope to see you on the field!
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
Unread 10-11-2015, 22:56
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Rookie Year: 2011
Bendito is an unknown quantity at this point
Our basic plan for the Rescue Beacon involves starting in a consistent position and using encoders and gyros to traverse the field. Then, a color sensor reads the beacon to decide which beacon pressing flipper (we call them "Color Wackers") to use. If the encoders do not provide reliable enough positioning, we may implement line following technology to do last minute realignment with the beacon based off of the white line. We already have color sensor on the bottom of the robot to detect tape colors to determine which way to turn (as the red and blue sides require different programs, automatic detection is one less thing for drivers to forget). The color sensor should work as a line follower as well.
Also fun would be tracking the center line with a color line follower, using trigonometry to calculate distance left to traverse in the hypotenuse before making the turn to beacon. The variable would be the distance taken (measured with encoder) taken to get to the middle. While overall accuracy isn't necessarily improved when compared to a consistent start position, it allows more variety as to where the robot starts. Of course, care must be taken to not cross the center boundary in the first 10 seconds, requiring clever sensor placement.
We are definitely going to the Allendale competition, and possibly the Freeland one.
Unread 11-11-2015, 06:10
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by Vikingtech2054 View Post
Full Run Attempt
Hey I wanted to share a quick video...
Excellent work! Thanks for sharing.
Unread 13-11-2015, 10:17
pokelogan89's Avatar
pokelogan89 pokelogan89 is offline
Logan Schorr
AKA: Logan Schorr
FRC #1086 (Blue Cheese)
Rookie Year: 2014
pokelogan89 can only hope to improve
Wow! Your robot looks amazing. Your claw/crane is quite an amazing device. Do you have any pictures/CAD for how your extensions are running? It appears to be belt, but I cannot be sure.
Unread 04-12-2015, 10:43
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
ditto on pokelogan's post....we've got several prototypes but they're primitive in comparison.
